Hi there everyone,
My grandfather has owned a Gottlieb big hit pinball machine for as long as I can remember, and I have some really fun memories of playing this machine. However, it seized up after a game several years ago and was left for quite a while because the keys were lost. I've recently gotten into locksport, so I took my pics to it and was able to get it cracked open pretty fast.
I'm no beginner when it comes to electronics, but when it comes to electromagnetic systems like this, I'm a little out of my element. I have ordered schematics in the manual from PBResource, but as this machine is located at our cottage, I only get a very small period of time to look at it each week. I'm wondering if there's anything I can do at the moment without the schematics that might help get the machine back up and running.
The state of the machine was exactly as it was at the end of the last game it played. The score reels showed 6000 points, and the runs counter showed 02 runs. When the machine is turned on, the normal back box lights go on, as well as the game over and tilt indicators. Dropping a coin through the acceptor would cause the score motor to turn one third and then stop. Manually pushing the score motor also causes it to turn one third and then stop. All of the fuses measure as being good.
I've been doing quite a bit of research into Gottlieb electromechanical systems, and it seems like this situation is related to some component of the machine not resetting to its default state. At the recommendation of some guides, I have tried manually resetting the score rotors by taking them out of the back box and incrementing them until they are all zero. I have also tried manually engaging the "S" relay. Now, whenever the machine is turned on, the score motor will spin continuously. While this is happening, the total play meter is incrementing about once every second and the bumper lights are turning on and off at the same pattern. I also notice some sparks between some of the relay switches, could that be the root cause of this issue?
Currently I'm working on reading the huge electromechanical repair guide at pinrepair, and it is great. But I'm wondering if there might be others around here who have the same machines who might be able to give me more specific advice. So far I've just been poking around, and I feel like I'm making the situation worse following these guides without really knowing what I'm doing. Any ideas?
Thanks,
Michael
