(Topic ID: 253411)
Gottlieb Big hit flipper problem
By bodine46
5 months ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 5 months ago by D-Gottlieb
    #1 5 months ago
    I have a Gottlieb Big Hit my flippers are dragging and starting to leave mark's on playing field what should I do to fix this problem. Any help is appreciated
    #2 5 months ago
    Remove the flippers and find out what is worn or adjusted incorrectly. The flipper bearings on that year machine rarely wear out, so you might just have to raise the flipper bats a small amount.
    #3 5 months ago
    Thank you for your help I really appreciate it
    #4 5 months ago
    More than likely is that your problem will be worn flipper bat shaft bushings. As the bats are constantly rubbing against the top of them, they slowly wear down to cause the bat to scrape on the playfield.
    These are a cream coloured nylon item that is held to the underside of the playfield with about 3 screws. Undo the flipper shaft at its base via its Allen screws or conventional screws and lift the flipper bat and shaft from the playfield and replace the bushings. Dont over-tension the return spring on the flippers as their solenoids have to work harder to work the flippers.
    Not a bad idea while you have these dismantled to check the linkages for wear, coil inserts and coil end stops and e.o.s switches too. That will give you good flippers again! If you buy an overhaul kit from PBR, all these, including the bushings, are in the kit.
    #5 5 months ago
    Quoted from Classicpinballs:
    Not the case in this machine. Gottlieb started using different mechs in 1976.
    Various Other Swag
    Shoot Again Pinball
    $ 5.00
    Doc's Pinball Shop
    $ 69.99
    $ 199.00
    Id Rather Play Pinball
    $ 85.00
    The MOD Couple
    $ 59.99
    Hardware
    Chroma Pinball
    $ 14.00
    € 222.00
    Buthamburg
    $ 7.00
    APB Enterprises
    $ 74.00
    $ 12.00
    $ 27.95
    $ 36.99
    Lee's Parts
    $ 300.00
    Gameroom Mods
    $ 2.50
    Doc's Pinball Shop
    $ 229.99
    $ 7,399.00
    Nitro Pinball Shop
    $ 235.00
    $ 349.00
