New! Dark mode!
(Topic ID: 156603)
Gottlieb Bank Shot - "special" not resetting
By njPinWiz
  • 4 posts
  • 2 Pinsiders participating
  • Latest reply 4 years ago by njPinWiz
#1 4 years ago
I've been searching websites, forums, etc. to figure out if my Bank Shot was scoring properly. All scoring including bonus on ball drain is working as it should. The one thing I did notice however: when you light the special by hitting all the targets/lanes (each target/lane lights up a pool ball number in the center of playfield, and when all 15 balls are lit, the special is achieved). The special does two things: it lights up the two kick-out holes and lights up the #1 lane at top of the playfield. Ball going over #1 lane or hitting either kick-out hole awards a ball as they should. They all stay lit until ball drains, then they should go out. Herein lies the problem. The two kick-out hole specials go out when the ball drains as they should. But, the #1 lane special stays lit, which it shouldn't.
So, I believe when the ball drains, and the "reset" occurs, it's not triggering the #1 lane special to "turn off". Any thoughts on where to start the trouble-shooting process?
#2 4 years ago
chk the settings for conserv or liberal. find out what is supposed to happen.
chk schematic for the center lane light, follow it back to the relay/step that triggers it.
you may have a relay sticking, and not releasing.
if you power it off/on with the lite lit, will it reset and go out?
#3 4 years ago
will check on that Dr. I haven't turned power on/off with WOW lit - so will give that a try and report back. Thanks.
#4 4 years ago
in looking at schematic, the "U" relay was in the path for the #1 lane. Turns out that one of the switches in the stack was staying in closed position upon ball drain and during reset sequence. Opened it up a bit, and now after ball drains and reset occurs, the switch opens & the WOW light goes off as it should. Thanks all for the help!
$ 69.99
$ 159.00
$ 99.00
$ 40.00
B & K Mods
$ 26.95
$ 38.00
Apparel - Unisex
Silverball Swag
$ 48.00
$ 12.00
€ 8.10
Buthamburg
$ 69.50
$ 3.00
Doc's Pinball Shop
$ 22.50
$ 19.99
$ 29.00
The MOD Couple
$ 39.95
PinBoss Mods
Playfield - Plastics
Ramp-O-Matic
$ 19.95
$ 334.95
$ 269.99
Various Novelties
Pinball Photos
TheDudeMods
$ 54.99
Pin Monk
$ 67.00
