OK, so I'm struggling.
This is the back of the balls played stepper on the Hi Dolly I'm restoring - I've marked the step-up and reset solenoids.
There are two issues, that I believe are probably related:
1. Game startup - where the stepper should reset to one position before first rivet, and then steps up one place to first rivet. Mine does not step up to first rivet. So I took a slow motion video, and I see that both solenoids activate, but the step up fires just before the reset. I'm guessing thats by design and somehow you can make adjustments on the stepper so that the reset goes in and out before the step-up goes back out (as they would indeed step up by one). Wow that's confusing I hope some smart pin person can make sense of that!
2. When the ball drains, the trough switch activates the step-up circuit. In one player mode, the step up fires twice, but my stepper only moves once. I used my handy "two-car-bulb-tester-thingy" on the step-up solenoid, and it does on indeed fire twice, but super quick. I figured this may have to do with the adjuster I circled in blue and perhaps tension of the long spring. I adjusted the blue one so the ratchet just falls into the next tooth which feels right, - but I cannot seem to get this double step to work.
The stepper overall feels like it moves pretty well, snaps back at reset, and steps-up smoothy when I operate both by hand. The two lever things on the shoulder bolts also seem to move pretty freely. I was hopoing not to completely dismantle this stepper, but I guess I can if the advice is that may be a contributing factor
Sorry for the long post - i should have been in bed hours ago but this thing is bugging the hell out of me
thanks
