The ax coil gets voltage on one side via the black wire that goes back to the transformer. It completes the circuit on the other coil wire through that series of switches, eventually getting to the red-white wire. The idea of the jumper is to bypass those switches to figure out which one isn’t doing its job.
Here are the steps that I would do.
Jumper from the red-white wire to the slate+red wire on the ax coil. If it doesn’t pull in, then either the black wire is not making a connection back to the transformer or the red-white wire isn’t connected to the transformer red wire via the counter switch.
If it did pull in, then I move to the brown+red wire on the make-break switch on the U relay. If that works, I move to the next switch. If it doesn’t, then I clean and adjust the switch until it works.
The process continues from switch to switch until it works. I also like to use the light bulb tester method that shows me the same thing. You take 2 12 volt car bulbs, solder a wire between them to put them in series, then solder 2 wires with clip leads on the ends. The same process is used as the jumper, but it visually shows you if you have voltage at each step.
Dave
