(Topic ID: 125662)
Gottlieb Atlantis question
By MeNaCeFiRe
  • 3 posts
  • 3 Pinsiders participating
  • Latest reply 4 years ago by DirtFlipper
#1 4 years ago
I am not getting points when I roll over or hit a lit Advance. When I look under the playfield I see both the 500 white target relay and 3000 point relay activate. If I manually press down the 3000 relay I do not get 3000 points. What should I be looking at here? Any help is appreciated
#2 4 years ago
If the 3k relay is activating, then the switch on that relay sends a signal to the score motor to actually score the points may not be making proper contact. I would explore that circuit to find the culprit. Could just be a bit dirty and need a cleaning.
#3 4 years ago
Quoted from stashyboy:
Agree. 'E' should cause the score motor to run, so if E activates (or you manually activate it) and there's no score motor running, then that's a great clue to pursue. In addition to the switch on E, there's also a Jones plug in between (to carry the signal from the playfield down to the score motor board). So can check for continuity from E to the Jones plug, to the score motor.
$ 399.95
$ 45.00
Pinball Photos
$ 55.00
Pinball Photos
2,199 (Firm)
Farmville, VA
$ 45.00
Pinball Photos
$ 5,799.00
Gulf Coast Pinball, LLC
$ 29.95
$ 87.00
$ 999.00
$ 29.99
$ 44.95
PinBoss Mods
$ 149.00
$ 194.99
PinballBulbs
