Quoted from Runbikeskilee:I've seen that one before on my Atlantis. Likely that the A relay is not unlatching. Check to see if it is mechanically hanging up or the reset coil is not getting signal.
I recently had the same issue as Uncle J: the score reels would reset but the F Relay kept going as did the score motor. I had a similar problem with another game and it was one of the score reels ZERO switch. But I checked all the score reels and they were making correct contact.
I came across this thread and saw Lee's post about the A Relay and remembered that I'd had a similar issue with Sure Shot Z relay sticking. https://pinside.com/pinball/forum/topic/gottlieb-sure-shot-bonus-count-issue-#post-6084166
I took the A Relay apart and noticed some black gunk on the top of the coil and the armature where it meets the coil. So I cleaned it up with alcohol and a green scrubby, flexstoned all the contacts on the switches and re-installed. It now works 100%!
Thanks for pointing this out, Lee!
Kinda weird that Gottlieb made 2200 Atlantis machines and three of them ended up within a half hour of each other in Maryland!
