My Atlantis has developed an issue with the target reset after all targets are dropped during a game.
When all targets are down, the game will score the last target (500 or 5000 if you drop white/blue for the last targets down) then scores 5000 and resets the targets.
Mine will score the drop target value properly, will score the 5000 but the bank just can't quite reset on the first shot, leading it to score an additional 5000, then it will reset. Sometimes it resets properly, sometimes it doesn't. The usual EM intermittent problem that drives us all crazy.
On the schematic, the G relay which is the bank reset relay activated by n/c switches on the C and D, a n/c 3D motor switch, and the switch on the bank itself that closes when all targets are down. There is a separate branch of the circuit which is a n/o G switch and a n/c motor 2B which appears to be a lock in circuit for the G relay itself.
I've cleaned and adjusted all of these switches, they are all correct. When I watch the sequence with the hood up, the G is trying to pull in but just can't quite get there, so it won't lock on and activate the big coils that pull in the bank reset mechanism.
The startup sequence, as noted, is correct and in any case, that's run off a motor 2C and isn't related to this process.
I've exhausted everything I know to do and check. Anyone see anything I'm missing here?
