Short version: Press red self test button inside coin door once and it goes into audits then immediately into lamp test 2. If I press the self test button twice when entering self test it goes to the second audit. Once I get to lamp test 2 (either way) I cannot go any further or do anything.
Long Version: Got a new to me Arena, this is my first Gottlieb. There was a burnt ground connector going to the transformer so I did the transformer ground mod before plugging it in. I found I did not have the proper crimp contacts for the interconnect mod (adding additional ground and 5v wires), so I am waiting for those to arrive in the mail. I have not added a ground wire to each board. When I turned on the game both solenoids for the saucers fire repeatedly. I then removed the solenoid fuse to disable all solenoids. I started trouble shooting by unplugging all connections to the cpu except J1 (power). Tested the CPU was getting 5v and it is. Added score display connector and it works. After connecting J5 (coin door) I tried to get into the self test and had the problem listed above in the "short version". I connected J6 (switch matrix) and tried the self test again with the same results.
Despite the self test problems I connected J4 (driver board) and turned on the game. It was cycling through attract mode. Self test still only lets me see audits and lamp test.
