Hi, Restarting this topic as it got lost in a couple of other "group" threads (ASM and Sys80). Attached picture are the replies received.
I purchased an Amazing Spiderman (Gottlieb series 80 not Stern) in early 2000's, and it's been my only pin for about 16 years. Recently I purchased my second pinball machine (Bally Paragon), and realized that my Spiderman flippers are really not that strong compared to the Paragon. My project for 2018 will be to try to get some better flipper action out of my Spidey. So... wanted to provide a bit of what I've looked at already and ask a few questions on the best place to start.
A) Voltages to the coils look good, and don't seem to drop off much when the flippers are activated.
B) All of them seem to be similar strength... none really stronger or weaker than the others... just all more sluggish than the Bally
C) EOS switches appear to be working correctly (leaf switch sparking so they're disengaging... which means they also engaging)
D) I've used jumpers to bypass the EOS switch in case they are disengaging too soon, and that doesn't seem to make the flippers any stronger
E) Some looseness in the mechanicals, which posts indicate can cause flipper power loss.
F) I'm assuming that everything is original parts (1980ish), but even if reworked before I bought it, everything is at least 20 years old
Questions
1) Are Gottlieb flippers, in general, not as strong as Bally's?
2) Although voltages seem good, is there anything that could be limiting power to the coils?
3) Lots of postings about rebuilding the flippers... relatively cheap investment... is that the best place to start?
4) Several posting about coils themselves not really getting any weaker over time.. is that correct? If not, would it typically be just one flipper coil "going bad" or would they all sort of get weaker over time. My Bally had some old coils in the cabinet, so I assume they were replaced... should I replace flipper coils if they're not obviously dead; or not?
5) Anything simple and obvious I should check that I haven't already? Experiments I can try?
6) What sequence of "improvements" would you recommend?
7) point me to prior postings or sites if this has all been covered lotsa times!!
Stephen
