(Topic ID: 218822)
Gottlieb A8 garbage DMD
By Benhurr
1 year ago
  • 11 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by arolden
#1 1 year ago
Hi every players
I start to restore electronic cards on a Stargate by changing Q1 and R3 on A2 but I did a bad soldered on Q1 and it result of burning the 12V fuse and A8 board...
So I change every recommanded parts on A8 but nothing appears on DMD and the game won't start.
I change U8 gal chip, the game start and work well but nothing on DMD
I buy a new DSPROM (who was also burned) and ask for a rev4 (note on the old one) but I received a rev3 and the DMD works with garbage (picture 2). As it is write on the 1st picture there's no rev4....? And rev3 work with rev4. Also change U5;6;7 U16;U17 on A8 and U11 on A1...but nothing better.
Is it a revision problem or something else?
Why do I have 4 players on DMD when I choose to play 1 player?
Thanks for any suggestion
#2 1 year ago
Currently sounds like a RAM issue
#3 1 year ago
Ok I Will change every RAM on A8 and see what it done.
THX
#4 1 year ago
Quoted from Benhurr:
THX
Shot gunning every chip on the board is not a good idea unless you're totally out of options.
Does the display look any different in test mode?
Try replacing U4 first as this is a common failure point.
#5 1 year ago
DMD looks same, I'll change much I can the RAM cost 6 euros and another 2 euros... 6 others are approx 0,5 euros and already spend 20 euros so...that is the last try or I might buy new A8 for 160 euros.
Thanks for your suggest
I will let you know if it works
Have fun
#6 1 year ago
So I replace every chip on A8 card, but always have garbage when playing movie scenes...but sometimes it also blinking and the red diode too at the same time...I ears a song coming from the DMD so I think it also could came from it or test the 12v
I will bought a new Dot cause it is out of gas...but 1st I need to find why does it blink...
#7 1 year ago
Have you replaced the components in the high voltage section?
#8 1 year ago
I've already changed those 20 pieces for A8 repair kit...might change all capa and diodes. Will did it next days.
#9 1 year ago
Step ...88 Change Crystal by new one but nothing better so I bought a new DMD cause the original one was out of gas after 24 years of good services.
Always garbage that appears at any movie scenes so I will change every capa resistance and diode left this week.
#10 1 year ago
Change D1 to D10 also C23 to C25 , C27 to C30 but nothing better on DMD.
Electronic seller tells me to clean any ribbon connector...already did fast with contact spray so I disconnect any A8 ribbon and scrape them all female connector too.
After reconnect A8 it seems to be a little bit better with complete movie scenes but some don't work (always same strange...) there are less garbage between sequences so I will bought all new ribbon cables.
Close to the end...I hope
1 month later
#11 1 year ago
How did you go with this? I have just replaced U9, U10, U11, and U2 on my display controller but no improvement. I have ordered a new U13 and U1 so will see if they help.
$ 42.00
$ 49.95
Pin Stadium Pinball LEDs
$ 15.45
KAHR.US Circuits
Gweem's Mods
2,800 (OBO)
Sale Pending!
Wappingers Falls, NY
3,000 (OBO)
Tulsa, OK
