(Topic ID: 230896)
Gottlieb 80b stand-up targets
By Topher5000
5 years ago
#1 5 years ago
I broke a stand-up target on my Raven & am going to order a couple. The somewhat local place, Playdium (Player One), has these listed, but they say they're for Williams machines. Will they work in a Gottlieb? They look similar.
http://www.theplaydiumstore.com/Stationary_Round_Target_Front_Mount_p/a-14691.htm?1=1&CartID=1
#2 5 years ago
Compare them with the ones Marco sells?
https://www.marcospecialties.com/pinball-parts/PFLD-TARGET-ST?S_CAT2=GOTTLIEB
Might help determine if they would work.
#3 5 years ago
Looks similar. I'm going to take a picture of mine & send it & measurements to them just to make sure.
#4 5 years ago
Hello,
No, no, no ! it's not exactly the same, even if it looks like it.
On your photo, this is targets for Bally/williams, not for Gottlieb.
Indeed, a fixed target (spot target at Gottlieb) is mechanically very simple. But what's different between Williams / Bally and Gottlieb is the mounting plate and the position of the two holes for the screws.
At Williams / Bally (your photo), the two screws are mounted parallel to the target. At Gottlieb, the two screws are mounted perpendicular to the target.
As you can see here (from Gottlieb parts catalog), the mounting plate and screw alignment is also perpendicular for slingshot contacts:
Look at pictures at Marco's, you will notice that the position of the hole is correct for Gottlieb.
Sure, it is better to take those of the same brand, to avoid redoing holes in the tray.
#5 5 years ago
Ah, didn't notice that! Thanks for pointing it out. I'll have them get the proper ones. They get their stuff from PBR.
Trade
Machine - For Trade
Smithfield, RI
$ 5.95
The Pinball Scientist
$ 1.00
Pinball Alley
$ 83.00
PinballReplacementParts
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-80b-stand-up-targets and we tried optimising it for printing. Some page elements may have been deliberately hidden.
