(Topic ID: 304755)
Gottlieb 80b - Slings reset the game
By SeymorGoldfarbJr
6 days ago
  • 11 posts
  • 2 Pinsiders participating
  • Latest reply 4 days ago by SeymorGoldfarbJr
#1 6 days ago
I’m working on a Hollywood Heat with a reset issue. Whenever any one of the 4 slingshots fire, the game will almost always reset. All other switches and functions of the game work fine. The slings are not cpu controlled. I’m looking for any suggestions on what to check at this point.
#2 5 days ago
What do you mean by reset? Does the ball end and go on to the next ball? Does the game end? Or does the whole pin reboot?
#3 5 days ago
Quoted from Nokoro:
As soon as any slingshot fires the display is filled with x’s, the game ends and goes immediately into attract mode.
#4 5 days ago
Is there a slam tilt switch in the game? If you trigger that switch, does it end in the same way? Just wondering if the slings are triggering the slam tilt in some fashion.
#5 5 days ago
Quoted from Nokoro:
I actually have the normally closed slam tilt wires soldered together. I’ve also check the other tilt and slam switches and they are set with huge contact gaps.
#6 5 days ago
Ok but does it do the same thing if you trigger the slam tilt? Even if the switch is open, perhaps something is causing it to trigger like a short.
#7 5 days ago
Quoted from Nokoro:
I’ll have to check the other tilt switches. The slam switches wires are permanently soldered together.
#8 5 days ago
I guess I’m just trying to figure out if they weren’t soldered closed, would a slam tilt cause the X’s to display. I’m trying to narrow things down. I don’t know a lot about Gottliebs. I’m trying to figure out if there is a normal cause for that reset and then work backwards from there to figure out why the slingshot is having the same effect.
#9 5 days ago
#10 4 days ago
Quoted from Nokoro:
When the system 80 get tilts, it says "tilt" on the display. This is giving me all x's, I do not believe it's activating any of the tilt switches.
#11 4 days ago
The reset board is also not plugged in on my game.
