Hey all! Just got my first pin, a Hollywood Heat that I'm sure I overpaid for (I missed one on craigslist for $600 a year ago and beat myself up, so I felt compelled to drop $1400 on this one)
Overall in pretty good shape, with at least two previous owners who did some modding on it-- a bad ground mod, a good ground mod, replacement MPU, leds, freeplay set up in the weirdest manner I've seen (hold the right front button and press start to add a credit? why not just tie it to one or the other?)
I'm doing my best to go through tons of topics and articles and wikis on 80Bs and look at all the normal maintenance and updates and such, as well as plenty of time spent reading about general troubleshooting. However, I'm not sure where to go from where I'm at right now.
There's at least one dead coil in the pf, which is fine, whatever, will replace later (it's one of the multiball kickouts) The others all work fine, except that 8-9/10 times, any of the four slingshots being hit will reset the game. Reset is maybe the wrong word here-- it game overs the current play session, plays the end of game music, etc. If I just tap lightly on one of the two slingshot switches, it'll fire, but any serious contact with the rubbers will, well, see for yourself:
edit: clarification, the pop bumper does not do this, just the slingshots
Since the switches for the slingshots work, and the solenoids fire, and it appears everything is correctly grounded, I'm not totally sure where to go from here, or what I should even start probing at.
And while I have you here-- the transformer has a power outlet built-in, which is rad if I decide to add undercabinet lighting or something down the road, but my outlet tester says it has hot and neutral reversed which... is not what I would expect unless a previous owner popped open the transformer and rewired it, though maybe that's expected?
