Quoted from Cheddar:Good info thanks. So that looks right.
While I'm a mostly certain that the power supply is fine I have another on the way to at least eliminate it as the issue. I have several more system 80 projects so it won't go to waste
I was reading through the system 80 service manual and they keep mentioning the 60v, 6v and an 8v DC offset. This does not appear anywhere but the output is of the power supply going to the transformer to create the filament voltages. And since those are present at the display that path is valid. But... Should the 8v DC be at the display as well? I see nothing on the schematics that would show this
On the A2 power supply, look at connector J1. Pin 6 (5 VDC) and pin 9 (8 VDC) are the DC offset voltages that are coming from A2 and being sent to the transformer to offset the AC voltages.
The AC voltages at the display boards have already been offset at the transformer...
A transformer can only input/output AC; the DC lines shown above are reference voltages that create an offset for the AC sine wave.
Did you measure the offset voltages coming out of the A2 power supply? Are the DC offset voltages correct and present at the transformer? If not, then the AC sine wave is not offset. However, for this to be the issue, both offset voltages would need to have a problem.
https://www.pinwiki.com/wiki/index.php/Gottlieb_System_80#What_is_the_DC_Offset_Voltage.3F
https://www.pinwiki.com/wiki/index.php/Gottlieb_System_80#System_80_.2F_80A_Power_Supply
If your A2 power supply is putting out all of the correct voltages at the test points, swapping it out seems pointless. Besides the MPU, what is common to all displays including the 4-digit? I looked at the ground schematic again and I was wrong, there are two different ground daisy chains. Most of the voltages are not shared across the 7-digit and 4-digit displays, except the 5 VDC.
If your display boards have all the correct voltages coming in, and they are grounded, and the MPU is good, they should be working. Did you verify all voltages on the power supply, including the pins and header connections? If your pin(s) are bad, a new power supply might exhibit the same problem.
