I recently began work on repairing a 1971 Gottlieb 4 Square. I've done a lot of the basic repairs needed, including flipper rebuilds, replacement of all of the rubbers, and most recently replaced the flipper and alternating relay coils.
My machine has developed a new problem, where when the ones counter needs to cycle over from 9 to 0, the 10s relay gets stuck energized. This causes the score reel to stick, as well as the 0-9 step unit to stay stuck energized as well. I have been able to release the relay by manually turning the back spinner on the 0-9 unit. Once I turn it, operation continues as normal until the ones counter needs to cycle over again.
The switches on the ones score reel appear to match the correct state for 9 while the machine is stuck energized, and then properly reset to the 0 state once I un-stick the step unit. The step unit is able to move freely otherwise for all other steps, and the alternating relay is still working correctly as well. The plunger in the 0-9 step unit is a little loose because the nylon ring that holds it is worn. In order to prevent the plunger from falling out of the coil, I had to adjust the coil down within the step unit. There does not appear to be any mechanical problem in the step unit since it is able to step regularly most of the time.
I do have a full schematic for the machine.
Any ideas what may be causing the relay to stay energized?
Thanks,
