(Topic ID: 164890)
Gottlieb 2001 Issue?
By Toyguy
7 years ago
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 7 years ago by NicoVolta
  • 2001 Gottlieb, 1971
#1 7 years ago
My Gottlieb 2001 is exhibiting an odd behavior. It seems to do it most of the time, but not always. The symptom is that all of the eject-type holes, including the outhole, act like they are on a hair-trigger. The ball just has to barely touch the hole and the game immediately tries to kick it out. It's really noticeable on the outhole as the kicker is failing to push the ball to the plunger on the first kick because the ball just hasn't settled into the hole enough. On the top holes, it's tending to punch the ball into the glass because the ball hasn't settled.
Is there anything that might be unique to these wedgeheads that might cause all of the kickers to behave this way? They do not always do it, but mostly they do. It's almost acting like the ball touching the metal arm is somehow triggering them. Is that possible? Doesn't seem likely that every switch is at fault.
Thanks for any advice. The game plays fine and everything works otherwise.
Dave
#2 7 years ago
Without a schematic in front of me, sounds like the score motor is not resting in the proper place between revolutions since it is all of the kick-outs. OR, the switch on the motor in series with the kick-outs and out-hole relays is barely making when it should not be. Easy enough to find without a schematic by raising the playfield and hitting the outhole switch while watching the score motor turn. The kickout hole switch will make towards the end of the motor rev and will probably exhibit a minor arch as the outhole energizes.
#3 7 years ago
I agree with Boatcat, the first thing I would check are the score motor switches.
Check the switch stack at motor 4C, these are almost always used for generating kick-out hole pulses. With the score motor in the home (at-rest) position, you may find one or more switches at 4C that are closed but should be open.
- TimMe
#4 7 years ago
Awesome, thanks guys! I'll take a look at those Tuesday on our repair night.
Dave
3 weeks later
#5 7 years ago
Regarding kickout hole strength, I find the coils at the top to be a bit aggressive. They fling the ball a little too hard, resulting in excessive playfield wear and/or whacking into the pop bodies and skirts.
I have restored two 2001 machines and the following recipe works very well:
Unwind 18 feet of wire from each pop bumper coil.
Unwind 18 feet of wire from each top slingshot coil.
Wind 36 feet of wire onto each kickout coil at the top.
This will give you livelier action at the top and reduce the kickout hole strength enough to save your playfield and pops.
I don't recommend unwinding the lower slings. They're peppy enough as-is. Otherwise you won't get to catch the ball enough.
Space Coast Pinball
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-2001-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
