Dear Pinside,
WHAT I GOT, WHAT I DID, WHAT I NEED INPUT ON (3 ITEMS PER TOPIC AND BELOW COMMENTARY).
I recently acquired a Gottlieb "2001" (1971). It is an attractive package and my first EM. 20 drop targets is interesting. Very much liking working on an EM.
This about summarizes what I did to it:
-Ensured proper operation of Score Reels "0" Position Switches
-Troubleshooted Score Motor running continuously on power up
-Someone had soldered Hold Relay switches "Always Closed" and switches were bent. Desoldered and restored switch function
-Cleaned Score Motor switches 3C & 1D
-Cleaned Jones Plug for 3 ball vs. 5 ball game (for awhile game would change up to 5 and back for now reason in 3 ball plug position)
-Reset Bank Armature Switch adjusted
-Cleaned switch contacts on Start Relay (S), Hold Relay (H), and Ball Return Relay (O)
-Initial cleaning of playfield with Novus 2
-Adjusted flipper EOS switches for longer stroke (improved flipper performance)
-Loosened flipper assembly spring tension (improved flipper performance)
-Left flipper "buzzes/vibrates" when held which appears to be a worn coil sleeve (planning to replace sleeves)
Interim Outcome, It Plays:
-"Stopped" continuous Score Motor running on power up. Reset sequence appears functional: Start Button --> Start Relay --> Score Motor --> Reset Score to 0,000 --> Reset Drop Target Banks --> Etc. --> Energize Reset Bank Armature Coil and Trip Armature --> Serve Ball
Now, the Topic re: Drop Targets Reset, Scoring, and "Loud" Reset Sequence...
1) BLUE AND RED DROP TARGET BANKS RESET
I do not get 100% success rate on resetting the Blue and Red drop target banks (Coming up say 60% of the time, sometimes "trying" and poking out through the playfield but not quite latching). Cleaning Score Motor switches seemed to positively impact success rate. 100% success rate on resetting the Green and Yellow drop target banks. I looked for any mechanical issues causing the Blue and Red reset assembly/armature to bind but nothing apparent.
Observing that the Green and Yellow banks reset in advance of the Red and Blue (by ? degree offset and ~1 second on Score Motor cam rotation).
It is that somehow the Red and Blue reset success rate is being compromised but why?
2) INTERMITTENT SCORING INCORRECTLY
Most scoring is in line with expectations... 1's, 50's, 10's, 300's. Intermittently and trending more around the 5 upper playfield ball locks (50 points or 300 when lit, etc.), expected 300 points may "score" (roll the reels) to +4,000 and then once X,000 where thousand digit is on the reel hitting same or other targets triggers this scoring of multiple thousands of points, even draining a ball will give me multiple thousands of points. Any ideas?
3) RESET SEQUENCE SOUNDS LOUD/BUZZY
Reset Sequence stills "sounds" wrong (loud/"buzz",etc.). That is, I enjoy the EM noises but I don't know if my Reset Sequence sounds normal. I have recorded a few video clips with audio, maybe a pinball intuitive can hear if anything is unusual. I will upload a few clips to YouTube if/when I receive some response to my thread. I can reproduce this same "buzz" if I manually trip the Start Relay. Sounds a bit "violent".
For general interest, I plan to:
-Install Orange Dot Flipper Coils (GTB-A5141B)
-New rubbers
-Various cosmetic items
-Playfield restoration
-Cabinet restoration
Please any insight on items #1, #2, and #3 above would be greatly appreciated.
Regards,
PhantomP
