(Topic ID: 203518)
Gottlieb 2 player Super Spin
By ddt007
6 years ago
Jet Spin.pdf (PDF preview)
#1 6 years ago
I am new to working on Pinball, used to play a lot, I have a Gottlieb Super Spin that i have cleaned up and replaced rubbers and light bulbs that were not working, had it working for a little bit, now i can not get it to start a new game, when i turn it on the game over and 1st ball relay energize, not sure if thats normal or not, but it will not do anything, any suggestion, HELP, thanks
#2 6 years ago
First, make sure there are credits showing on the credit reel. Also, check the coin switches to make sure they are in the open position. You can do a "force" start on the machine by manually pushing in the start relay (S relay) to see if it will begin the reset process. If you have a multi-meter, you can determine if there is any voltage at the start/credit button switch. With credits showing on the credit wheel, there should be approximately 25 volts at the start/credit button switch...
#3 6 years ago
Check out the V and S relays at 17 on the schematic, esp. the AX relay in the middle of the sequence. Also make sure those two motor switches are clean and gapped right. AX should have a nice snap to it when adjusted correctly.
Jet Spin.pdfJet Spin.pdf
Lighting
Space Coast Pinball
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-2-player-super-spin and we tried optimising it for printing. Some page elements may have been deliberately hidden.
