When the replay button is pushed, my Top Score attempts to reset the score reels. Sometimes the numbers move 5 higher only. If I try again they will increase one number only. Another try, another number, etc until all are at zero.
The previous owner had tried to fix the game for three months. He managed to offset the Player Unit bakelite arm by 120º and stretched out the Player Unit springs very tight. I have no idea what else his shotgun approach 'fixes' altered.
After the initial partial reset of the score reels, the game plays and scores mostly as it should. But new scoring is added on top of the old score.
I have (1) checked the score reel switches and they seem to open and close at the right time: 0,1-8,9. (2) I've cleaned the P3 and P4 switches and checked that they open and close with the cam teeth. Also checked P2B and the R relay make-break switch. (3) I've checked the AX relay and the switches change state when I manually activate/deactivate the relay.
I've searched other threads and couldn't find the same problem but once, and that faded away without resolution.
Someone else must have run into this problem before and can help. What have I missed? What should I check again? This machine has come a long way but the score reel reset is frustrating me. I am bettering my skills but am still relatively new to repair and schematics.
