Hi All,
Im trying to get this machine (not mine) working properly. Originally when power-on and try to start a game, the score reels did nothing, the playfield would just flash and the score motor would just spin. Here is what I have found and done so far....
I found a handful of things that needed attention first.
- There were a number of score reels that had wires detached, it was obvious where they went so i soldered those back on.
- I found several broken switches on the score reels (small stack with 2 switches, EOS and carry over... I think thats what they are called). I replaced those.
- I found 2 of the frog-head switches that were not in the proper ladder slot, I repositioned those
- In the backbox, I noticed the "L" and "N" relay switches were actually out of the switch ladders so I was able to put those back in place.
- On the board in the cabinet, I found the relay switches for the AX relay were also actually out of the switch ladder and I was able to put those back in place.
So, now with all that taken care of all be 3 score reels reset to 0.
Player 1 the Ten Thousand and the 100 units do not reset. I will compare the switches to Player 2 switches figuring they should be the same.
Player 2 the Tens Unit does no reset. This is where my question comes in (sorry for the wind storm above but I was just trying to give background info).
See picture below, There is a double black wire dangling and I am not sure where it goes? Also why is this housing different than the others, there is no coil just a plunger, Im thinking it's missing the coil and housing, then they would all look the same.
I was told the machine worked when they got it, but if it did, probable not well.
thanks
Steve
