Quoted from millsy:Having problems with startup but would like to sought out the coin door wiring first. Soon as power turned on score motor runs continously, replay button non responsive - the 2 wires displayed were joined together otherwise all other coin door wiring seems to be intact. Disconnected the 2 joined wires and the motor runs and stops,it is set on free play. Should the HOLD (G) relay be energized on power up or only when Start relay manually activated. (At the moment I have the playfield out )
Fitted temporary start button at those 2 coin lockout wires.
First senario
1.manually set scores on all the score reels to zero, manually reset all the stepper units to zero, unlatch any interlock relays (AX & BX & CX relays).
2.Turn Machine on.
3.Tilt & Game Over displayed at backbox, Q (Game Over), U (1st Ball), H (Tilt Hold) Relays are ENERGIZED.
4.Manually activate S (Start Relay)
During Start-up
5.Score motor turns, Score Reels Reset to 0, Player Unit Resets, AX relay energizes
Start-up Completed
6.Score motor stops, AX relay De-energizes Q (Game Over), U (1st Ball),H (Tilt Hold) Relays are ENERGIZED. Game Over displayed at backbox.
Second senario
1. manually set scores on all the score reels , manually reset all the stepper units to zero, unlatch any interlock relays (AX & BX & CX relays).
2. Turn Machine on
3. Manually activate S (Start Relay) Whilst manually holding R (HOLD) relay through out the start up sequence.
During Start-up
Score motor turns, Score Reels Reset to 0, Player Unit Resets, AX relay and BX relay Energizes.
Start-up Completed
Score motor stops, Player 1 and Ball 1 displayed, can manually activate score wheels.CX relay latched.
Then when manually releasing the R (HOLD) relay
Bloody late Gottlieb - wish it was a Bally.
No mention of the R (Hold) relay on the startup sequence literature, I do have the schematic but still struggle with the wiring road map.
When and how does the R (Hold) relay function ?
