I'm rebuilding my flippers on my 1971 Gottlieb Playball using a rebuild kit from pbresource. I was able to get the left flipper aligned without issue - but the right isn't cooperating. I think the spring is pulling the plunger-link assembly just enough to cause it to stick. I thought a stronger spring might do the trick, but after creating a little more tension on the spring the problem is still there. I've spent the last 2 hours trying every thing I can think of without success.
Anybody out there ever experience the same issue?
TIA
Allen
