(Topic ID: 297597)
Gottlieb 1963 Power Issue
By megoman
2 years ago
  • 8 posts
  • 6 Pinsiders participating
  • Latest reply 2 years ago by megoman
#1 2 years ago
I have a Gottlieb Slick Chick game I’ve been working on. Literally just fixed the final 2 or 3 small issues so game should now be working 100%.
Had to remove playfield as part of the final fix (I’ve done many times before). Reconnected the 4 Jones plugs (1 to back box / 3 to cabinet), plugged game in, hit start and NOTHING.
Manually engaged the Hold Relay - NOTHING
Reseated Jones plugs … NOTHING
Checked wall outlet - OK
Checked power cord - OK
Checked fuses - OK
Checked Cheat, Shutoff and Bounce switches.
- OK
Seems there is no power flowing. It’s got to be something simple that I’m overlooking. What is it?
Many thanks in advance for the help
#2 2 years ago
I'd start by figuring out how far power is getting into the game. Service outlet working? Power at the line cord fuse? Transformer? Any additional anti-cheat switches been added that you might not have noticed?
Anything happen if you hit the left flipper button or try to add credits?
#3 2 years ago
Thanks for the note
What was missing from my original post is that game had been working. Was fixing a few last things that had been problematic.
So, played a game. Unplugged game. Removed playfield. Removed knocker coil to inspect. No issues so put back. Cleaned a stuck score reel.
Then reconnected playfield and that’s when nothing worked.
Out of the blue there is suddenly no power after essentially only pulling off some Jones plugs and putting them back in.
#4 2 years ago
check the wires on both side of the jones plugs. Maybe a cold solder joint let loose.
Quoted from YeOldPinPlayer:
I recommend using use a multi-meter to see where you lost power. (Continuity)
Check both sides of the circuit.
I had issues when a common Yellow wire came un-soldered.
#5 2 years ago
The tilt switch on the coin door carries 110 volts and is one place where the game will be totally dead if it isn’t conducting adequately.
#6 2 years ago
Check the tilt/slam switche(s) on the score motor board and coin door. Jumper around them, if necessary.
Ran into that on a Gottlieb machine from the same era not too long ago.
#7 2 years ago
If the Replay button doesn't trip the Start relay (SB) on the relay bank,
Inspect and diagnose this circuit with Alligator clip jumper wires
https://pinside.com/pinball/forum/topic/gottlieb-big-shot-repair#post-6305153
http://www.planetimming.com/Pinball/troubleshooting/EM%20Troubleshooting.pdf
http://www.pinrepair.com/em/index3.htm#features
Example of a pinsider actually doing this https://pinside.com/pinball/forum/topic/red-baron-tech-question#post-5858156
Be careful because this circuit runs on 120 volts
#8 2 years ago
Thanks to all for the feedback.
Used my handy Klein Tools voltage tester. With the game plugged in there was current all throughout the game.
The only thing stopping power going to the “other rail” so to speak are the 3 cabinet switches which need to be closed (anti-cheat/shut-off/bounce).
I thoroughly went through these three switches and there was a bad connection on one of them that I must have missed when I originally looked.
With that switch now properly connected the game has powered back on.
Thank you all again for the input. Fairly new at this so learn by asking, getting help and then doing. Love Pinside.
1,200 (OBO)
Shaker Heights, OH
$ 12.00
1,800 (Firm)
Staunton, VA
Cabinet Parts
Cabinet Parts
Space Coast Pinball
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-1963-power-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
