So, before you rebuilt the pop bumpers, was the machine working as it should except for the pop bumper lites were out? And now, when you start a new game, do I understand correctly that the machine completes the startup routine and then the tilt lite for player one illuminates?
If so, I suppose it is possible that one of the tilt switches is completing a circuit to the tilt relay and that perhaps you accidentally caused one of these switches to stay closed when you were working on the pop bumpers. Do you have the schematic? I’ll check mine, but usually there are a few switches that could be responsible for this.
And with regards to the pop bumper lites, the bottom one only comes on at particular bonus values (I forget which but I think it is every four steps on the bonus stepper). And then two of the top four (diagonal pairs I think) come on one pair at a time (e.g., the upper left and bottom right and then the upper right and bottom left).
Quoted from Segerfan:The large coli in the bottom I thought used to stay engaged while game was on. I pushed it in and tilt light when out but the coil made a very loud buzzing noise. Any ideas on what I should do. Is it the coil or something else?
I assume this is a bank reset coil. It should fire during the startup routine but not stay engaged. It would reset the tilt relays (that are part of the relay bank), but shouldn’t stay engaged. I don’t think this is your problem, but does this coil fire during the startup routine?
And raising and then lowering the playfield shouldn’t be related to your problem either.
