I'm not sure (and my machine isn't easy to move right now and so I can't readily look at this). It's possible that there's a normal leaf-blade switch on the backside of the balls played stepper that opens when the stepper is at zero. Nonetheless, if your hitting the balls played stepper (when you were working on the bell) has something to do with the problem of the machine not resetting, then it could be that that switch is associated with the fingers on the stepper unit.
Quoted from Segerfan:As you stated before it is hard to tell if the SB relay is engaging .I'm pretty sure it isn't. I watched it very closely over and over.
But if the SB-relay isn't engaging during the start up routine, then as far as I can tell the bank reset coil shouldn't fire when you manually reset the balls played stepper. I tried watching my SB-relay when I reset my machine, and I couldn't see that the SB-relay was engaging--though perhaps you have a better view than I had. You can turn the machine on, restart the machine, and then unplug the machine and manually inspect the relay to make sure it isn't engaging (as it should be in the engaged position at this point if it is actually engaging). Can you get a photo of the SB-relay to indicate its state at this point (that is, whether it is engaged or not)?
And I agree with your notion that something you did while working on the bell caused this new problem (with the failure to restart) arising. Knocking the balls played stepper's zero balls played switch could do this (that is, prevent the restart sequence from completing because the balls played stepper doesn't reset). Nonetheless, the balls played stepper not resetting could also be due to the SB-relay not engaging, but again I'm not sure what you could have done in the backbox that could be keeping the SB-relay from engaging. Your hitting the fingers on the stepper is a clue that suggest it is the zero balls played switch if indeed the switch is completed via the stepper's fingers.
If this were my machine, I'd do the following: First I'd determine whether the SB-relay is actually engaging or not during startup by doing what I suggest above. If the SB-relay is engaging, then I would figure out which switch or contacts on the balls reset stepper is the ZERO BALLS PLAYED switch and then I would inspect this switch and then attempt to jumper across this switch to see if this causes the stepper to reset. It sounds like the balls played stepper is reseting when you manually reset it, but if this isn't the case, I would make sure that the balls played stepper moves well and isn't gummed up (and not able to reset itself). If these strategies don't work, then I would check the connections on the balls played stepper reset coil and maybe jumper directly to it from the ZERO BALLS PLAYED switch to see if there is a loose connection here. If, on the other hand, the SB-relay isn't engaging, then I would attempt to (safely with a small dowel or something nonconductive!) manually engage it after reseting the machine to see if the balls played stepper resets and then attempt to figure out why the SB-relay isn't engaging.
Good luck!
