Hi Matt
infamous Relay Bank ? You mean the "loved Control-Bank" ? - about the "AX-, BX- etc. Interlock-Relays here: https://pinside.com/pinball/forum/topic/ax-bx-dx-relayswho-hates-these ...
I believe You either have AAA or BBB or CCC or DDD.
AAA: The R-Hold-Relay NEVER pulls-in - the coil on the relay may be bad or the wiring is bad.
BBB: The R-Relay does pull-in - Yes, R-Relay pulls-in as the S-Start-Relay pulls-in --- BUT the R-Relay also "let go" at the time (somewhat later in the Start-Procedure) when the S-Relay let go.
CCC: The R-Relay is nice and behaves - it pulls-in and it stays pulling forever (well stay pulling until You toggle-of the main power switch) --- BUT a Switch on R-Relay IS FAULTY.
DDD: well maybe - but I doubt this rather strange fault: You have a fault on XB-Last-Ball-Relay combined with O-Ball-Return-Relay.
Whenever You just look into the pin or when You work on the pin: Toggle-off the pin - MUCH BETTER: UNPLUG the 220 Volt power cord (Safety Reasons - 220VAC, 110VAC, 24VAC, 6VAC can kill You !!! The "Coil resetting the Control-Bank is operated by 110VAC !!!").
Toggle-off the pin, unplug the main power cord. Manually RESET the Control-Bank - doing so You make the pin cnange to state "I am at end of Start-Up-Procedure - I am IN PLAY - I am ready to play Ball-1, Player-1".
In the Control-Bank WATCH the Game-Over-Relay - plug-in and toggle-on --- see the Game-Over-Relay plunge / move ? This phenomena is WANTED --- Gottlieb WANTS to have the pin in "Game-Over" (when toggling on the main power switch) - so the Gottlieb-Pin then shall easily start a new game.
Now watch the R-Hold-Relay - it is not pulling. Start a new game - the S-Start-Relay will pull-in --- question: DOES the R-Relay pull-in ? IF (if) "No": You have "AAA".
Keep-on looking at the R-Relay - does after some time the R-Relay LET GO (stops pulling) ? IF (if) "Yes": You have "BBB".
IF (if) "No - the R-Relay does not let go --- means it is nice and friendly - it stays pulling: You must investigate in (my JPG, encircled red, 3-bladed, ) the Make-and-Brake-Switch on R-Relay. When the R-Relay is pulling: The middle blade (having soldered-on wire-red-white) MUST have - must have ONLY contact to the blade-having-soldered-on-wire-red-green. When the R-Relay is pulling: The middle blade is not allowed to have contact with the blade-having-soldered-on-wire-maroon(brown)-green !!! (faulty contact / connection to maroon-green CAUSES Your "strange fault", means "CCC").
(((The "DDD" would be (my JPG, encircled orange stuff) --- please first look for AAA, BBB, CCC and report, ))) greetings Rolf
