(Topic ID: 237944)
Gottlieb Top Card
By Geertsen
5 years ago
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by Geertsen
#1 5 years ago
Hello everyone. I have a Top Card pin. During play it skips ahead the score and I could hear relays chattering. I found that the EOS on the ones was snapped off. I've replaced that. Then the problem got progressively worse. I've cleaned all contacts in the backboard, target contacts, all male and female jones plugs. Checked rollover and ball lane switches. As I clean things, the problem gets worse. It starts up normal, resets to 0 then when I advance the ball, the score rattles up to around 8000 and all the score reel relays lock as well as the rollover relays. I will not have my schematic until next week. Any input would be appreciated. Thanks
#2 5 years ago
Quoted from Geertsen:
Does one reel only add, or all? If only one, check for stuck PF sw.
#3 5 years ago
I had a machine that did that, the jones plugs were reversed. The count of the jones plugs were the same and there was no color code to let you know which side went where.
Doubt this is your problem but just throwing it out there.
#4 5 years ago
All the reels go nuts. I just checked the jones plugs, they all have different amounts of plugs so it is impossible to switch them around
#5 5 years ago
It's possible, however, to install them backwards in the correct plug. Not easy, but possible.
#6 5 years ago
Thanks for the replies. It was a too close switch on the 100s relay
This page was printed from https://pinside.com/pinball/forum/topic/gottleib-top-card and we tried optimising it for printing. Some page elements may have been deliberately hidden.
