Quoted from Blake:Disagree.
There is an industry of technicians/repairman using fiberglass erasers and have been for decades. The goal is to remove oxidation not the plating. Fiberglass erasers work great for that. If someone continues to use it on one contact well after removing the oxidation then they might need to understand better what it is they are trying to accomplish. If that’s what your referring to when you say “grime” then again I disagree and highly recommend swapping out the #2 pencil for the proper tool to do the job.
Deoxit is great for its cleaning ability. Not magic. But helpful in tight spots like sockets. Spray on the IC legs after cleaning and insert into socket. Remove and let dry/blow out then resocket. If connections are still poor swap in new sockets as they are more then dirty. Wiping down finger contacts after cleaning mechanically provides further cleaning.
I'm not talking about a pencil eraser nub. Something like this:
If the contacts are corroded sure, you'll need to use more aggressive measures. However for most games I've encountered, the contacts are usually just a dirty, and maybe lightly tarnished.
I used to have a before & after photo I would post demonstrating this, but I can't seem to locate it. I'm sure I've posted before on the forums somewhere.
Sure, it's a solvent. Almost entirely naphtha. I have a can of it, though I think I've only ever used it once or twice. It wasn't that useful to me.
I don't normally clean sockets, but that's an interesting approach I hadn't heard of before. I usually just replace sockets if they're being troublesome, especially the poor quality ones that are well known for being problematic.
For chip legs, normally I use a rubber eraser as well, unless they're pretty gnarly. Then I may attack them with a fiberglass eraser. If they're too far gone (like some problematic 80s Bally chips), then I'll just replace.
Just don't do it with your breath. All the Nintendo groups warn about this with game cartridges. That tends to accelerate oxidation.
I brought it to the silverball show this past summer. Still plays great
Just on Friday--I had other events happening on Saturday. So, I didn't end up bringing a game this year.
