It looks like the top switch is not set up correctly with the Wire Lever (#3 on image)
Here is a good write up on score reels (where I got the image)
http://homepinballrepair.com/index.php/em-score-reels-gottlieb/
Here is another link for the open/close sequences
http://www.pinballaustralia.com/gotreel1.htm
or
http://www.pinballaustralia.com/gotreel.htm
I've done allot of reading and they said usually the sequence is score real specific BUT their is a generic setup on pinwiki.
WOW, You're correct, It does look stacked incorrectly... shaking my head.
Here is the generic stack ...
https://www.pinwiki.com/wiki/index.php?title=EM_Repair#Score_Reel_Switch_States
going home will let y'all know
thanx
I would compare it to another score reel on the same machine. With the power off, Manually pull the the plunger and see how the stack moves.
Check the schematic, it will show the open or closed value when the score reel is at zero.
no schematic and somone played with all the switches i'm setting it according to :
Quoted from DirtinLa:no schematic and somone played with all the switches i'm setting it according to :
Good luck. Hope it works out. Keep us posted on your progress.
This page was printed from https://pinside.com/pinball/forum/topic/gottleib-magnotron-decagon-reel-switch-stack-sequence-please and we tried optimising it for printing. Some page elements may have been deliberately hidden.
