With j1 plugged in and j2 unplugged I have 5v on pins 1-8. So can I move past the power supply? In the very beginning I only didn't have sound, it went into a attract mode and I had display. I adjusted the voltage up to about 5.3 V and was able to get sound and display in attract mode. I thought I fixed it so I shut the power off to put the cabinet back together. Once I turned it back on I had solid lights on the boards. I dialed back the voltage and was able to get a flashing light on the CB to go into attract mode but lost display. At that point I unhooked the soundboards and rebooted to see if I can get the display working without the soundboards causing a problem. That's when I started blowing the fuse to the power supply.
