(Topic ID: 106882)
Gotta check your wires.
By jasonsmith
9 years ago
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 9 years ago by jodini
#1 9 years ago
You know with every new machine I always go through all the wires and their solder joints etc. This is what I found on my AX relay. I had to bend the tab (closest to you) down to make the gap but you can see when it was bent up, the new solder job that someone did lined up perfectly with the upper contact. You can also see where it was arching and where things got a bit toasty.
#2 9 years ago
Good find and repair Jason. Those can be tough to figure out unless you see visible burn marks or heavy arcing going on when the machine is running and you have the Playfield up.
Ken
#3 9 years ago
See that little bare jumper wire between the two lower switch stacks? I had one that had cracked solder joint on one side & made intermittent contact. Took me FOREVER to figure it out....
Yeah, you got to inspect every wire!
#4 9 years ago
Oh wow, that's a crazy one as well. Gotta be sure of your troubleshooting skills and keep looking where you believe something is to catch an issue like that.
#5 9 years ago
So true...I always check the backside of my stacks (or at least try too)! You should put some tubing or tape around that one...that's close!
#6 9 years ago
Quoted from jodini:
Oh it's getting re-soldered. The scary thing is all the fuses were wrong as well, wrong the bad way too.
#7 9 years ago
Quoted from jasonsmith:
They always are, aren't they? I have yet to get a new to me pin that had the correct fuses installed.
Seems like 20A is a favorite.
#8 9 years ago
Paper clip fuses...those are my favorite!
$ 1.00
Pinball Alley
Las Vegas, NV
$ 5.95
The Pinball Scientist
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/gotta-check-your-wires and we tried optimising it for printing. Some page elements may have been deliberately hidden.
