(Topic ID: 247930)
Gott Sweethearts Operational Question
By cody_chunn
#1 4 years ago
Took my first look at a customer's SH tonight. It was working fine, then suddenly went wonky. He described it as all the lights "reversed". Currently, at game start, some of the backglass cards are lit, none of the playfield cards are lit, none of the rollover numbers are lit, a couple of the pops are lit, a couple of the orange lites leading to the standups are lit.
So my question is: What lites should be on at game start, and what causes the lites to come on or go off.
Thank you for reading, and gratitude if you respond!
#2 4 years ago
This seems to be a weird common issue with this game. My friend has one which also developed a similar strange lighting problem. I was tearing my hair out trying to find the cause, but eventually "fixed" it by simply running an additional wire lead from the lightbox GI common to the playfield GI common. It seemed to solve the symptom, but I can't figure out what the actual cause is.
#3 4 years ago
Quoted from jrpinball:
Thank you!
#4 4 years ago
At start up all cards on BG are not lit.
The Cards on BG only light once the corresponding rollover is completed.
At Start up all PF inserts (cards) are lit and go out once that rollover is completed.
The pop bumpers are not lit at start up, but do light up once rollover just above each pop is completed.
The 5 lights inline with the stand up target on left and right side located at bottom 1/3rd of PF
are all out at start up (except leading insert lite), but when a corresponding rollover is completed at mid field or exit lane,
then one of those other spot inserts will light up for extra scoring potential when stand up target is hit (i.e. 10pts per lit insert).
#5 4 years ago
Fantastic! He has the schem on the way, and with this post I am feeling pretty confident. Probably mostly gonna be that giant relay bank...
Cabinet Parts
Space Coast Pinball
This page was printed from https://pinside.com/pinball/forum/topic/gott-sweethearts-operational-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
