Gottlieb Super Circus - This machine will not power up. The kick-off switch is closed and clean. There are some coin door hacks that appear the slam switch has been disconnected with the wires spliced together. All the "jones" plugs have been cleaned. All fuses tested and are good.
I plug in the machine, operate the "K" relay and nothing happens. I short what I believe are the coin switch wires and nothing happens. I operate all relays manually and nothing happens. No lights, no motor, no click - nothing. I cleaned the K relay contacts but nothing changed.
In desperation I ran a clip lead jumper that likely couldn't handle 1A current flow, from After the 5A main fuse directly to the transformer. The 5A main fuse blew, my jumper was OK. I pulled the 1A fuse for the AC coil reset circuit and tried again with the same results.
I find the black leads that I think come from the main fuse on the K relay. I see red wires on the other NO contact lug as per the schematic. But there is no continuity between the red leads/contact and the transformer.
See schematic section associated with the AC main power circuit. Also a pictures of the K relay and transformer. The power lead input to the transformer are the left top 3 lugs with the middle lug unused.
