New! Dark mode!
(Topic ID: 189367)
GOTLE Bent Ramp - Issue?
By toro1966
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 3 years ago by toro1966
#1 3 years ago
Hey guys - I'll start by admitting I pretty retentive - so this may not be a huge issue, but I am also not a Pinball Genius so I would like some opinions if that's OK.
I have had my GOTLE for a little less than a year or so, and this is the first time I removed the upper playfield to wax and clean underneath. I cleaned and waxed when I bought it, but didn't do under the UPF . Pictures below are how the ramp is installed. It is definitely bent slightly, and you can see under the screw the tab actually looks like it was creased and then straightened. I assume this happened on installation because I have never had it apart and I noticed this BEFORE removing the screws to disassemble the UPF.
So my question is - does it matter? Is the fact that one end doesn't quite lie flat an issue? It doesn't seem to affect game play - or I would have assumed I would have noticed it before now. Assuming I want to fix it, how do I do that? Yes, I have thought about trying to bend it back, but my experience on other pins is that the spring steel is so thin, you end up doing more damage to it trying to bend it back.
The ramps are riveted to the rest of the ramp, so do I have to replace the entire ramp? Again, any of your thoughts would be appreciated.
#2 3 years ago
Not a problem. Play on!
#3 3 years ago
If it bothers you that much it isn't that difficult to take that ramp off and straighten it out.
#4 3 years ago
Thanks for the replies guys.
Biggest question I had was whether it would do any damage over time. As far as taking the ramp off and straightening it, I might try that, but again, my experience is that because these things are so thin, it usually just makes it worse. If I took it off, it would probably be to replace the ramp - including the spring steel pieces - which I assume come riveted on the new ramp.
Mods for your pinballs
$ 65.00
Lighting - Backbox
Arcade Upkeep
$ 54.99
$ 16.00
$ 54.99
