GOTG Sound Replacement Mod
(Topic ID: 209520)
By cleland
1 year ago
  • 535 posts
  • 128 Pinsiders participating
  • Latest reply 11 days ago by acedanger
  • Topic is favorited by 123 Pinsiders
There have been 21 images uploaded to this topic. (View topic image gallery).
7 key posts have been marked in this topic (Show topic index)
There are 535 posts in this topic. You are on page 11 of 11.
#501 60 days ago
I would like to try the 8gb one, the other is just too large for my slow internet to handle.
#502 60 days ago
Great work again cleland
Can I edit the image file edit in PinballBrowser so I can keep my high scores?
#503 60 days ago
Quoted from applejuice:
I'm not sure why the image size went to 16gb, when the original stern card were 8gb ones? I had a look at the image for the pro and made an 8gb version for my game. That way i could continue using my spare 8gb card. There is just a load of unallocated space on the card for the remaining 8gb of it.
original 16gb card
trimmed to 8gb card
If anyone wants the 8gb version i can upload it to dropbox, and/or happy to send to cleland to if he wants it.
Cheers
Cleland added assets and used a 16gb SD to be safe. The RAW image assumes a 16GB card since that is what he used when the image was created.
#504 60 days ago
Yup, I just sent a request to applejuice to send me the Stock PRO 8 gig .img file and I can run the macros and repost the files to be at 8 gigs.
cpr9999 alerted me of this and it was corrected right off the bat for the LE Images. The links will remain the same, I will just replace with the Pro 16 gig versions with 8 gig versions to cut download times and use smaller size SD cards.
#505 59 days ago
Here is the trimmed pro image if anyone wants it
https://www.dropbox.com/s/yhuhrhnu1y0vola/gotg-cleland106-8gb.img?dl=0
I can send over a clean stern 8gb image of 1.06 , but it will take me a few days as I don’t have an image of this currently.
Added 58 days ago:
Removed download link now from my dropbox share, as cleland's information now supersedes this.
#506 58 days ago
Big thanks applejuice, sinestro , and cpr9999 For all their help with disk imaging.
To make it easy, here are links to all current 1.06 versions for both PRO and LE/Premium.
PRO Cleland Version 1.06 (Features Music Change and Movie Lines)
https://www.dropbox.com/s/zsraz2lqjinfimk/GOTG%20CLELAND_PRO_1_06.img?raw=1
PRO Sinestro Version 1.06 (Features Stock Music and Only Movie Lines Replaced)
https://www.dropbox.com/s/lzt00yswin0qd4m/GOTG%20SINESTRO_PRO_1_06.img?raw=1
LE/PREMIUM Cleland Version 1.06 (Features Music Change and Movie Lines)
https://www.dropbox.com/s/8ylj6nderwtztq2/GOTG_CLELAND_LE_1_06.img?raw=1
LE/PREMIUM Sinestro Version 1.06 (Features Stock Music and Only Movie Lines Replaced)
https://www.dropbox.com/s/n9pvvs45unmc1he/GOTG_SINESTRO_LE_1_06.img?raw=1
#507 58 days ago
Awesome, thanks guys.
Just a tip on posting dropbox download URLs. If you remove the dl=0 and change it to raw=1, the files automatically start downloading instead of taking you to the dropbox website when clicked.
ie: https://www.dropbox.com/s/zsraz2lqjinfimk/GOTG%20CLELAND_PRO_1_06.img?raw=1
#508 58 days ago
Quoted from DeeGor:
Well thanks for that tip! Links have been changed to reflect that now.
#509 58 days ago
Cleland, what's the difference in the 4 versions? Are two of them 8gb and two of them 16gb?
You might want to mark what's what.
#510 58 days ago
Quoted from Sinestro:
Pro Cleland
Pro Sinestro
LE/Premium Cleland
LE/Premium Sinestro
They are all just under 8 gigs and will fit on an 8gig are larger SD card.
#511 58 days ago
Quoted from cleland:
Pro Cleland
Pro Sinestro
LE/Premium Cleland
LE/Premium Sinestro
I had a brain fart.
#512 57 days ago
Cleland for the win. You have made this game awesome!
#513 56 days ago
Picking this up soon. Sorry if this has been requested but is there a version with rubber band man?
#514 55 days ago
I'm on hols now so I decided to have a go at a new file based on the sinestro/cleland version. I updated the main tune songs so there is more variety in them rather than just the 4, but kept the stock mode score music. I also changed the I want you back end of game music to the chain.
Main song playlist is now:
Cherry Bomb
Hooked on a feeling
Aint no mountain high enough
The Chain
Come alittle bit closer
Moonage daydream
Lake Shore Drive
Fox on the Run
The Rubberband Man
Surrender
I Want You Back
So the game picks from the above when you are out of mode.
and Mr Blue Sky for mode select (from the Cleland version)
If nobody objects I can share this version for use via pm. I will probably try to improve it little to as I get time. Of course this is just a small tweak from the awesome work by Cleland
#515 55 days ago
PMed, I'll try it out!
Cherry Bomb
Hooked on a feeling
The Chain
Moonage daydream
Lake Shore Drive
Fox on the Run
The Rubberband Man
Surrender
I Want You Back
#516 54 days ago
Thanks to Cleland and everyone else , my machine came with the Cleland audio already on it from prior owner nevus so after playing a few games with the stock audio after the 1.06 upgrade can now really appreciate how much better the Cleland audio is !!
In particular Cleland does not own a gotg anymore but still put in the effort to work with the upgrade, many thanks!!!!! pm sent
#517 53 days ago
Just installed - this makes it super awesomely radically groovy!!! Thanks for all your work on this!
#518 47 days ago
Any videos?
#519 47 days ago
Subbing for updates and possible ownership down the road
#520 27 days ago
I am a proud new owner of GOTG. After all the positive feedback on the Cleland mod I want to make this update ASAP. I've successfully downloaded the zip file to my USB but when I plug it into my pin for update it is not registering on the machine for an update. I've already updated the software to 1.06 and had no problems with recognizing that update. Any idea what I may be doing wrong or what the issue might be?
#521 27 days ago
Quoted from Sasquatch:
The Cleland files are meant as a memory card replacement, not a memory stick type update. You need to get a 16 or 32 go memory card and copy the unzipped file onto it and then swap it out with the one in the game.
#522 27 days ago
dylanfan71 thank you for the quick reply! Makes sense, I will give that a try.
#523 27 days ago
Follow the instructions on post #387. Works great
#524 22 days ago
Is there a post somewhere that lists what everything that is actually changed by installing the mod?
#525 22 days ago
Quoted from f3honda4me:
Hundreds of lines of dialog.
Depending on what version you use, a few extra songs.
#526 22 days ago
Ah so there's a lot to it, not just songs. Callouts, movie lines, etc, the whole works. I take it by the reviews I've read that it's a must have mod for GOTG.
#527 22 days ago
Basically, Stern had voice actors recite the exact movie lines, as well as alternative, but similar lines.
Cleland's mod replaces the movie dialog from the voice actors to the actual audio of those lines from the actors in the movie. You then go to settings and select the game to only use the movie lines.
It also replaces some of of the game specific instrumental music with additional songs from the movie soundtrack.
Cleland also offers the "Sinestro" version, which only replaces the voice actors, but leaves the stock instrumental music in place.
#528 22 days ago
Thank you!
#529 21 days ago
Thanks for the heads up. I did not know this and just went and checked my machine and it was set to both original and alternates, so I switched it to original movie lines only. Played a few games and did not really notice a difference. When does it use the alternate lines if set for both?
#530 17 days ago
Hey guys.
I apologize for my ignorance here. When I swap back and forth from Cleland pro to Cleland/Sinestro pro I can't tell a difference. From what I'm reading they are supposed to have different songs right? They sound exactly the same to me.
What exactly is the difference supposed to be?
#531 17 days ago
Quoted from imagamejunky:
Hey guys.
Sinestro version does not have any songs replaced, keeps stock music.
My version replaces most songs with songs from the movies. You might not actually be changing versions? You'd know right away, pressing start will play ELO's Mr. Blue Sky upon start.
#532 17 days ago
Quoted from Gorgar123:
It's random. The lines are slightly different. If you don't have the movie memorized, you may not notice the difference.
However, it is crucial that you turn off the alternative lines when you use this mod. Otherwise, it will switch back and forth between the voice actors (reading the alternative lines) and the movie audio lines....making it a mess!
#533 16 days ago
I didnt know that, thanks
#534 16 days ago
Thank you for replying Cleland. However the songs are the same. I downloaded both pro versions from your post #506 above. I've compared them both in pinball browser. And yes they both have Mr Blue Sky.
#535 11 days ago
Love the upgraded sound mod. But for some reason it's distorted on certain parts of Sanctuary mode. Sounds muffled. Does anyone else have this problem. Thanks.
Professor Pinball
Little Shop Of Games
$ 38.00
$ 89.99
$ 149.99
Flip N Out Pinball
$ 40.00
$ 125.00
Sparky Pinball
$ 27.95
$ 26.95
5,799
Milford, CT
€ 40.00
$ 5,799.00
$ 13.00
Pin Monk
Lorton, VA
$ 12.99
Sparky Pinball
$ 78.00
Professor Pinball
