I cannot get the 2 right side flippers to work Swapped out the fuses. Nothing. Upper playfield is working okay. I want to play..HELP! LOL
Check the flipper button switch, if that don't do it follow the path untill you find the problem. Use a digital multimeter to check the voltage at each point etc...
Quoted from DarthPinhead:I had this problem when I got my SW and it was a loose flipper wire and it just had to be soldered back on
+1,If you dont find a loose wire then check the driver board connections.
Do you have the manual?
Yes, I have the manual.......looks like a small phone book . Didn't find any loose wires on the flippers. Man, it is torture not being able to play right now.
Hang in there labguy. Im sure its something simple we just gotta track it down. Give those connectors a wiggle and keep looking for loose or broken wires. I find it odd that both flippers are dead so I really think theres a break in the chain.....or something silly like that.
Quoted from LabGuy:I cannot get the 2 right side flippers to work Swapped out the fuses. Nothing. Upper playfield is working okay. I want to play..HELP! LOL
Do you know how to use the Portals diagnostics? Go into the solenoid tests and see if the flippers work in test mode. Report back.
Oh and, if you didn't know, you will have to enable the high voltage for those tests to work correctly. There are two white interlock switches to the left when you open the coin door. The top one can be pulled out and locked for the HV.
As Cliffy mentioned run it thru the solenoid tests - if they check out then run it thru the switch edges test and press flipper button to make sure the switches are also working.
If one of those doesn't check out then you can work from there.
If the upper playfield is working then I can assume the flipper button works - but I dont have a TSPP so Im not sure how they have that built could be two switches etc.
keep us posted
Just take the glass off and use your finger for the right flipper only. Then when you find the problem put the glass back on and play with the flippers.
Nope, can't find any bad connections. Do I have to remove the coils to check them with a DMM? Just set to ohms and see if I get a reading? Can't I just unsolder the 2 leads and check them?
http://www.ipdb.org/search.pl?any=TSPP&search=Search+Database&searchtype=quick
Find the repair manual thread and start reading. The link above has some good documentation, but not factory repair info, (not on that page, but maybe in a link there).
Quoted from Cliffy:Do you know how to use the Portals diagnostics? Go into the solenoid tests and see if the flippers work in test mode. Report back.
Follow these steps first like cliffy has mentioned
If you mean using them navigating on the menu, they both work. Also, the upper playfield right is working. Maybe I will put the working left coil on the right and see if I get movement?
pinmike, TSPP is a Stern/Sega Whitestar game. Similar to DE, there are only two lugs on the coils and only one winding. So he's going to need to troubleshoot similar to the DE/Sega methods rather than WMS.
Let's recap this:
-It sounds like the flipper switches work in diagnostics mode, so the switches are good.
-You stated that the lower right and middle right flipper do not work during the tests in diagnostics, right?
-The right upper playfield flipper works, right?
When you say you swapped the fuses, you swapped them with known good fuses?
If nobody comes up with more info tonight, I'll try and look into this more tomorrow.
Stangbat, you have it correctly. Upper right playfield is working, although it sticks a little sometimes. When I got the machine, I got a whole box of NOS rebuild parts and many packs of slo-blow fuses. I think I will replace every fuse on that board. I am hoping to locate a few coils locally today. Should have them for backup them anyways.
Okay, first things first, Stern does provide tech support for their games, even in situations like this when you buy a used game from someone. So if all else fails, you can call them at 800-542-5377. Also, the flipper information is on page 106 of your manual.
First, let's verify that you are getting 50v to the two flippers that aren't working. Lift the playfield up, leave the coin door open, and pull out on the white upper coin door power switch located on the lower left of the coin door inside the cabinet. This will enable power to the coils.
Next, find the red-yellow wire that goes into the playfield fuse block for the upper right flipper. Put your meter on DC voltage mode, put the black lead on a ground braid in the cabinet and the red lead on the fuse block where this red-yellow wire is attached. You'll probably read around 65+ volts. Let us know if you get a voltage reading.
This page was printed from https://pinside.com/pinball/forum/topic/got-my-1st-pin-tsppbut and we tried optimising it for printing. Some page elements may have been deliberately hidden.
