Quoted from DuckBrian:I'm just guessing that that is an unpainted example
I think I saw another photo (in the TPF thread?) where there was not even dark grey between the boulders yet.
Quoted from markp99:I think I saw another photo (in the TPF thread?) where there was not even dark grey between the boulders yet.
Hmmm, I just assumed that was the shading from being recessed
Is it possible to get unpainted walls? And when do you think battering rams and walls will be available?
Quoted from markp99:Mezel, looking good! Could look a little more grungy on the paint job. A bit too tidy for a medieval castle wall...
The prototype is not painted yet.
Quoted from AJ51:Is it possible to get unpainted walls? And when do you think battering rams and walls will be available?
Sure and this week for the pro and early next week for the premium/LE
Quoted from Tmezel:Sure and this week for the pro and early next week for the premium/LE
pm sent
Here's the 2 prototype mods. Totally amazing & necessary!!!
I went ghetto & sharpied black on the 2 front arches just to have a little fun. No color added yet to front castle panel & didn't put on the side castle walls yet.
Ram is so much better than NIB part which is just a rectangle with a sticker. This ram mod looks so good, it looks like it should have come with game.
Looks good! Ram looks to be a bit heavier that the stock ram. Any results to report about the hit/success rate?
Quoted from markp99:Looks good! Ram looks to be a bit heavier that the stock ram. Any results to report about the hit/success rate?
I have played with several of the prototypes and I did not notice a difference. If it changed the game play I would not sell it. Just like the stock one, it needs almost a direct hit.
Quoted from labnip:Here's the 2 prototype mods. Totally amazing & necessary!!!
Just curious. Why did you take out the plastic track the ram runs in? Should be able to remove everything without taking that out right?
Castle Walls Are looking good even unpainted. I will Order them together with the RAM when they are ready. The only small Detail I don't like is that we will loose the White Walker reference on the castle black shot. I would have liked a shield there to put a Sticker with the white walker king above this Shot.
Quoted from chuckwurt:Just curious. Why did you take out the plastic track the ram runs in? Should be able to remove everything without taking that out right?
Was a little toasted that day...
But from what I can remember, think we had to pull it all out to get the ram to come out fully. Think the ram was stuck in there.
Quoted from labnip:Was a little toasted that day...
To get the original out you have to remove the bottom bracket. Its just a quick removal of 6 screws. The ram was installed at the factory first then they attached the castle.
Quoted from Tmezel:To get the original out you have to remove the bottom bracket. Its just a quick removal of 6 screws. The ram was installed at the factory first then they attached the castle.
Must be a different setup than the Pro. I assume that's why you have two different Rams available on your site? I almost bought the Prem/LE by mistake.
Quoted from chuckwurt:Must be a different setup than the Pro. I assume that's why you have two different Rams available on your site? I almost bought the Prem/LE by mistake.
The pro is easier. The toughest part is removing the top plastic and dealing with the little black spacers. When removed they roll down the playfield and putting them back in is a small challenge. But worth it.
Quoted from labnip:Black spacers from hell
Hehehe...
I still owe Marcos for the spacer I borrowed to make the two I lost in your game.
Quoted from Tmezel:I still owe Marcos for the spacer I borrowed to make the two I lost in your game.
Tell them I'll buy something (more) from them to cover it
Hehehe...
Try a glue stick to tack them into place just long enough to reassemble.
Quoted from Tmezel:The pro is easier. The toughest part is removing the top plastic and dealing with the little black spacers. When removed they roll down the playfield and putting them back in is a small challenge. But worth it.
Yep. Gotta be careful with those guys. I've taken my ram out twice already and luckily haven't lost any of them yet.
What kind of turnaround time is typical from payment to shipment? My first purchase, so not sure what to expect.
Quoted from chuckwurt:What kind of turnaround time is typical from payment to shipment? My first purchase, so not sure what to expect.
I think Kristin says 5 days. A new product may be delayed due to popularity. You can always send her a note via [email protected].
Quoted from labnip:My first mezel mod purchase was the TSPP duff beer can. Think I got it in 1 to 2 weeks.
She must of did that on purpose.
Quoted from Tmezel:She must of did that on purpose.
Pretty sure I selected the "cheap bastard" shipping method to save a few pence
Quoted from Asael:The only small Detail I don't like is that we will loose the White Walker reference on the castle black shot. I would have liked a shield there to put a Sticker with the white walker king above this Shot.
For sure, there's a lot of opportunity there. Even just a plain flat plastic in the "opening" where we can stick whatever image we'd like.
For Castle Black, the archway could even be sculpted and/or painted to look like the cold is creeping out of the door and onto the castle...bricks frosting over, icicles, etc.
For Choose Your Battle there could be a large shield/weapon/whatever. Maybe it's backlit to blink with the "Choose Your Battle" insert...maybe it switches color to match the house you're fighting. That shot is really important, but the castle covers so much of the PF that it gets visually lost (especially for new players).
It would be cool if all three shots have more character, because nothing reads very well on the stock game.
We are certainly struggling with this. We do plan on finishing it. It's already designed, having issues getting the master produced.
Quoted from Tmezel:...It's already designed, having issues getting the master produced.
work faster
Are there any news about the walls? I want to order walls and the ram but cause it has to be shipped oversea I want to wait with the order until I could order both.
This page was printed from https://pinside.com/pinball/forum/topic/got-mod-development-thread-by-mezelmods/page/3 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
