New! Dark mode!
(Topic ID: 141950)
GOT kicks ass!
By Pdxmonkey
5 years ago
  • 6,644 posts
  • 422 Pinsiders participating
  • Latest reply 36 minutes ago by EightBallTexas
  • Topic is favorited by 114 Pinsiders
There have been 834 images uploaded to this topic. (View topic image gallery).
There are 6644 posts in this topic. You are on page 132 of 133.
#6551 71 days ago
Quoted from chuckwurt:
So when you hit the right orbit for the first time during a ball it feeds the upper playfield? IE. Can you EVER enter the upper playfield or throne via the right orbit or plunge?
Right - is you get one trip to the upper playfield at the start of each ball. Whether that’s on the plunge or shooting the right orbit, that’s your choice.
If in Castle MB, the right orbit should always feed the upper playfield.
If mystery is lit, shooting the right orbit should feed the throne.
Wrong would be the game not doing this. I’m wondering if your diverter (not the two way gates) is working.
Hi Chuckwurt. The throne is fed OK from the right orbit, the issue is getting the ball from the right orbit to the upper field, even during multi-ball. That tells me there is something wrong with the diverter, right? During the diagnostic testing I hear the sound from the diverter when I hit the test button, which tells me that something is working. I will examine it more closely, may even take it apart to ensure that everything is OK. I'll keep you posted. Thanks for your insights.
#6552 71 days ago
Quoted from AvidPinPlayer:
Is the switch at the top of your right orbit working? If the diverter works in test but not in the game it would be because it's not recognizing the ball is coming. That switch is what activates it on a plunge as well as a right orbit shot.
I pointed the switch out here:
#6553 71 days ago
That was going to be my next suggestion. Does seem weird that he can get the ball to the throne though. I would think nothing would work.
#6554 71 days ago
I checked the switch you suggested and it works. Also I played a game and the ball goes to the upper playfield during Castle multi-ball.
#6555 71 days ago
So the only time it doesn’t work is via the plunge? Maybe something is misaligned and isn’t allowing the ball to go in there.
#6556 71 days ago
Can you manual plunge and see if it goes up there? I know on mine once the playfield starts getting dirty the button plunge doesn't make it but manual plunge does.
#6557 71 days ago
I don't recall off hand but is there a setting that turns off the ball going to the upper PF off the plunge? If so, I wonder if he has it set to not allow that to work.
For AvidPinPlayer - The only things that would cause that are:
- Some sort of setting. I don't recall one but asking someone more knowledgeable above
- The ball is bouncing over the switch on a plunge. I've seen this on other games before. Don't recall it on GOT. You can test this by taking a slow motion video of the ball plunging and when it doesn't go into the VUK you can see if the switch was hit. You can do it without a video by putting it in test mode for switches. Put a ball in the shooter lane and see if that switch registers when the ball goes past it. Will need a quick eye though.
- The auto or manual plunge is not strong enough to keep the ball on the ball guide and thus make it in the VUK.
My strongest suggestion is to set a camera up to show that area. Plunge the ball to see if it makes it or not. Do that 3-4 times. Find the times it didn't make it and look to see if any of the above occur. The good news, if the diverter works in test mode, it works on throne shots and for castle MB shots, then you know those mechs work properly. I still think it's the switch that isn't sensitive enough, is flakey or the ball is bouncing over it on a hard plunge.
#6558 71 days ago
I don’t have enough experience on my premium to know, but seems like an odd setting to have.
#6559 71 days ago
Will do all those checks. I have not changed any setting. I had not played the pin in over a month as I bought Elvira HOH and have been playing it a lot (may be GOT is jealous . The code that has is V1.37 from July 2019. Will keep everyone posted in case anyone encounters this type of problem in the future. Thanks.
#6560 71 days ago
mine has always missed the upper pf here and then on auto plunge. manual goes harder and increases the odds of it making it up there. i think it's not always supposed to go up there. i'd say mine goes up there 90% of the time.
#6561 71 days ago
Mystery resolved. Two weeks ago I installed a shooter lane protector. This protector created enough of a gap that would not allow the switch at the plunger to signal the left orbit gate to open and allow the ball go through to the VUK. I removed the new shooter lane protector and ... it is now working perfectly. Conversely, I could leave the shooter lane protector and adjust the arm of the switch in order to recognize the ball, but since this pin is HUO I'll just leave the shooter lane protector out.
Thanks to everyone for your support and guidance.
#6562 71 days ago
Great! Glad you figured it out.
#6563 70 days ago
Glad you got it working. Ditch the protector and just put some mylar down. I do that on all my games and have never had a shooter lane chip or wear.
#6564 55 days ago
Hello,
Anyone crazy enough to change the arts on the PRO version to some alternative cabinet arts? I would love to see some alternative arts, is one the biggest dowsides on the PRO version.
#6565 55 days ago
Quoted from RGAires:
Hello,
It’s not that bad. Now the back glass....
#6566 54 days ago
Aloha All,
Checking in and down to 30 days before my baby arrives...All mods are in closet ready for installation. This is going to be a good winter.
Thanks again to everyone that has help me find some cool pieces, some must have's and some just quirky stuff.
Cant wait to post up some pics end of sept or maybe 1st week of Oct.
I will do a video of the transformation and pop it in here once all pieces are complete...
Have a great Sunday.
P.S For any dog lovers, our new puppy arrived and yes her name is Lady Sansa.
#6567 52 days ago
Love to see an update with this..
- Added a new skill shot rule:
- Activate by holding in the left flipper button and plunging the ball
to the top lanes.
#6568 48 days ago
Is just me or you dont have a callout for the super jackpot on the HOTK?
#6569 47 days ago
Correct. Just a sound effect.
Actually the only SJP in the game with a callout is blackwater.
#6570 47 days ago
I wish they could fix this Ive seen some streams on your GOT Pro, amazing explanation of the rules, and gameplay, remember what is the level pintch you use?
#6571 47 days ago
Steep. Back legs all the way out. Front legs all the way in.
#6572 47 days ago
Yeap i see it, gameplay very fast. That the way your should play it. Thanks
#6573 44 days ago
Anyone have a custom shooter rod available for sale?
I like the look of either of these
22E27A24-53D3-4FC3-BB21-10C2B2DA63B2 (resized).jpegC96BE85B-58EC-4DEE-93CA-DCC4AA787755 (resized).jpeg
#6574 40 days ago
im trying to level my machine...
ive read on the forum that should be around 6.5, ive setup the machine almost the highest i can, but i can only reach 5.4...
ive attach some pics of it
pasted_image (resized).pngpasted_image (resized).pngpasted_image (resized).png
#6575 40 days ago
Are you trying to level it or get the pitch to a certain degrees? What issues are you having? Your leg levelers let’s look to be in the same. I would trust the bubble level in the shooter lane. It could be sitting weird.
#6576 40 days ago
Level is OK, im trying to set it to be a little more faster(pitch to around 6.5), i think this game screams for that, at least is the way i like to play it.
Im using an mobile app to read it, not using the bubble level.
I belive that the leg levers should be enought to level it to 6.5, but i cant get it, that why is ask to confirm it with other users.
#6577 40 days ago
Get longer leg levelers for the back. Not sure why you are getting a reading of 5 something. Mine was at almost 7 degrees when the levelers were like yours.
The levelers on the front legs of your game look way longer than the ones in the back. Is that true?
#6578 40 days ago
Yes, is very wierd... you have any pic of your bubble level?
That is a valid question... i can check that for sure
#6579 40 days ago
6.8 degrees. Bubble dead middle.
9D39AE3F-80FC-43AB-9923-1C184FED8239 (resized).pngE1FD36E8-4520-45B8-A7F8-7F7C17D2266D (resized).png
#6580 40 days ago
6.8 degrees. Bubble dead middle. [quoted image][quoted image]
nice thanks, that can be helpful to others also.
Are you using any especiif app that i can download? maybe im measuring it on a diferent unit.
#6581 40 days ago
PinGuy app. I think it’s only on iPhone though.
#6582 40 days ago
I think I had that one on Android before, not sure. The one I use now on Android is called Clinometer and it works well and is a free download.
#6583 40 days ago
Yeap i got it,
My app was not working correct, ive download an app Pinball Leveller and is working and giving the correct info.
Glad i ask in the forum, and thanks Chuck
#6584 38 days ago
With how often my phone get's dropped I don't think I'd ever be able to trust it. I use a digital level that I got from Home Depot for about $35. It stays with my pinball tools and not in the garage as I have a different one for wood working as I drop it to much. Seems to be a theme here. Wish I could blame it on drinking but I'm just clumsy...
#6585 33 days ago
Recently started my new Pinside shop and slowly but surely adding various items ... I really love my Ghost dire wolf so I'm making more in case anyone else wants one! He's perfect for the back right corner on the Pro. I don't have a Premium/LE nearby to toy with, but you guys are creative, you could probably find him a home.
https://pinside.com/pinball/market/shops/1282-rocket-city-pinball/04231-ghost-dire-wolf-mod-for-game-of-thrones
RCP_Ghost1 (resized).jpgRCP_Ghost2 (resized).jpgRCP_Ghost2a (resized).jpgRCP_Ghost3 (resized).jpgRCP_Ghost4 (resized).jpgRCP_Ghost5 (resized).jpg
#6586 33 days ago
Quoted from SkyKing2301:
https://pinside.com/pinball/market/shops/1282-rocket-city-pinball/04231-ghost-dire-wolf-mod-for-game-of-thrones[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Drill a hole in the head and add one red led and I am a buyer...cmon man you can do it..
#6587 32 days ago
Finally reach and complete iron throne... a lot of work and focus to reach it, and nothing... no especial ending... no fireworks... this needs to be fixed
#6588 32 days ago
"Today is the Day"
I pick up my almost brand new GOT LE that has been sitting for years in a room and almost no plays. Thanks to all who helped me with my questions .
A big thanks to all the mod folks who hooked me up ( Too many to list) , made me items and just were cool with my pleads for certain items no longer made.
Let the modding begin and here I come Iron Throne.
Have a safe and great day Pinheads.
#6589 32 days ago
Don’t hold your breath. Haha
#6590 32 days ago
Dont pop my noob bubble man...HAHA.
#6591 32 days ago
I bet you feel the same... a bit disapointing...
#6592 32 days ago
A lot of wizard modes are lack luster. Outside of the fanfare for completion, I think Iron Throne is awesome.
#6593 32 days ago
I doubt I will ever see it....not a pinball wizard like you guys...just going to enjoy the journey.
#6594 31 days ago
I just joined the club and love the game just as much as I do on location. I’ve got a ColorDMD and Shaker coming but anyone else have anything they consider a must have mod?
I’ve also in the middle of changing the lighting and rubber to more my style of al sunlight Comet.
I did get to Iron Throne already with Targaryen so I think I will need to set it up a little harder.
#6595 31 days ago
Quoted from Waxx:
I did get to Iron Throne already with Targaryen so I think I will need to set it up a little harder.[quoted image]
Get there using Greyjoy if you want more of a challenge.
#6596 31 days ago
Was just going to say that. Any Iron Throne is an awesome accomplishment, but Targ is definitely the easiest path by far. Stark can also be "easy" if you use direwolves on the dragons. Basically, dragons are mean and are usually the only thing standing between me and the throne, LOL. I've only done it a few times in the 3+ years I have owned it, and only once I think with something other than Targ or Stark. I have barely ever played as Greyjoy at all...I know my limitations, LOL!
#6597 31 days ago
Yeah and even if you have a premium and try to cheese all the modes with the upper playfield, the game makes you play out targ 3 if you’re Greyjoy. That mode is so hard. So make shots are needed. Such an intense mode and so satisfying when you complete it.
#6598 31 days ago
Quoted from Waxx:
Quite a few must have mods....I listed mine out some posts...cant recall what page..Here are just a few..
Tooper
Pinwoofers Audio Bad ass kit
HD Glass
Pinstadiums to make it light up.
Speaker lights and grills.
Welcome to the club.
#6599 31 days ago
Greyjoy is a tough one for sure. I have been trying out Lannister to try and blow up Stark/Lannister on Blackwater with multipliers. Is there any interesting strategies with other houses in the new rules? I haven't quite figured out how to play the other houses yet.
Thanks everyone.
Oh and I did put Invisiglass in it already and the pyramid plastic was broken so I just ordered a mod to replace it as they are cheap.
#6600 31 days ago
Try Baratheon and play wall multiball over and over.
$ 139.00
Sparky Pinball
$ 259.95
Pin Stadium Pinball Mods
5,000
Rochester, NY
$ 26.95
