Quoted from T7:Keep working on it - this is key to fixing your orbits IMO you should widen the mounting holes more to get more adjustment flexibility.
Did you buy the game new or used? If you bought it used, there may be a mod installed as an attempt to help the left orbits. If so, you will probably want to remove that mod as it may be causing the poor right orbits
It’s a used game, I took diverter mech completely out of the game to Widen the mounting holes in it. Pretty positive there are no other modifications back there. All rubbers are still on the top of lanes too. I should probably try and get them off. I’ll keep messing with it.
But there is really very little room to move any further straight forward. The shaft the diverter arm is connected to is already up against the wood of the playfield. Since the holes in the metal mount are widened there is some play side to side also. But it seemed when I started messing with different positions I would sometimes lose diversions to elevator. Oh well it’s not the end of the world. I did see a few full left orbits when playing last night.
