(Topic ID: 82559)
Gorgar wiring
By Cali9dub
10 years ago
  • 13 posts
  • 4 Pinsiders participating
  • Latest reply 10 years ago by barakandl
#1 10 years ago
I was trying to swap my old plasma displays with PinScore LEDs, however there appears to be a problem with my original wiring. One of the plugs (small left hand side one with 6 wires) has a wire running fom it that goes to each display. I know this is wrong. Does anyone know where each of those 6 wires should go? I see 4 of them running to the power supply. Here is a pic of the plug. It has 6 spots for wires. 5 are filled and one of the 5 has 2 wires coming out of it. The 2nd of the 2 is the one running to all of the displays.
#2 10 years ago
Help. I know that double wire is wrong. Should I just pull it ??
#3 10 years ago
That is the +100V to the displays. Normal.
#4 10 years ago
If that's normal and one single wire is jumpered to each display individually then how do you hook up PinScore displays, besides...doesn't look normal.
#5 10 years ago
I haven't ever used pinscore displays, but they aren't going to need 100V so I would imagine they just ignore it.
If you feel like what you have is super weird looking, maybe post a pic of it so we can see what you are talking about.
#6 10 years ago
This should help you out.
http://firepowerpinball.com/downloads/MasterDisplayBoard.pdf
The high voltage is not used on your LED displays. I would leave that wiring in for backwards compatibility though.
#7 10 years ago
Is that brown wire normally split off seperately to the 4 players displays? I've tried to see pics of the wiring, but I don't see anything showing that brown&white wire being spliced in 4 directions. Is that splice to each of the displays normal. And thanks big time for that drawing with the colors included !!
#8 10 years ago
If you use the LED displays, you can just take the 100v fuse out completely.
A component or board can't burn up if it does not have power.
#9 10 years ago
Fuse is out. I'm still trying to find an answer if my wires were cobbled together or correct.
#10 10 years ago
Each set of wires going to each individual display has this connector for that 100v wire and the loom coming from the power supply has that wire jumpered off and spliced into 4 connectors that attach to the one shown (on each display)
#11 10 years ago
Normal
#12 10 years ago
Ok. Just seemed like the display driver would deliver that along with the rest of the wires in the connector as opposed to having that one wire jumpered individually to each display. Weird.
#13 10 years ago
That is pretty standard practice. Bally loops certain bus voltages around in the same fashion. The +43v in the backbox takes many hops in a bally.
$ 69.00
Pinball Pimp
$ 65.00
2,900 (OBO)
Franklin, VA
Tools
Pincoder Store
$ 1.49
Daddio's 3D Printed Mods
$ 859.00
$ 42.95
Newcastle, OK
$ 69.00
Pinball Pimp
$ 27.95
$ 170.00
Displays
Digipinball Shop
$ 100.00
The Flipper Room
This page was printed from https://pinside.com/pinball/forum/topic/gorgar-wiring and we tried optimising it for printing. Some page elements may have been deliberately hidden.
