This is my first solid state machine, so I thought I'd run through a battery of tests before turning it on to make sure I don't blow anything up. I disconnected everything from the power supply board except for the power coming from the transformer. I've done a voltage tests for all the pins on the power supply board, and I'm getting some higher than specified voltages on certain pins.
The manual says that 3J3-4, 5, 6, 7, 8 and 9 (solenoids and flippers) should all read 28 volts. But my meter reports 41 volts for each of those pins. Also, 3J4-5 through 8 should read 18 volts, but they instead read at 21 volts.
It's possible that I'm testing these pins wrong, but other tests come up as they should, and I'm using the specified grounds for each of the pins that are giving me weird readings. Is there something that I could be missing to explain these higher-than-normal readings, or has a component failed somewhere?
UPDATE: I found a schematic online that says if 3J3-6 through 9 are "OV" (over voltage?) then fuse F2 might be blown. I used my DMM to take out and test the connectivity of that fuse and it won't beep. All the other fuses beep when taken out and tested, though. F2 is a 2.5 slow blow fuse, so maybe that's why it won't beep, but I don't think that's how they work.
The explanation for over-voltage on 3J4-5 through 8 is that F3 might be blown, but that one tests positive for connectivity when taken out and tested. So now I'm trying to figure out why that one shows 3 more volts than it should. Maybe that doesn't matter. I think 41 volts instead of 28 does, so I'm going to pick up a few 2.5A slow blow fuses from Home Depot tomorrow. We'll see where I'm at then.
