(Topic ID: 284607)
Gorgar startup issue
By Boltronix
21 days ago
  • 12 posts
  • 7 Pinsiders participating
  • Latest reply 16 days ago by PinballManiac40
#1 21 days ago
Gorgar will not start. I replaced all boards in Gorgar with Kohout boards. The game lights up when powered up but will not accept credits and start up. No sound. Also only player displays 2 and 4 light up. Players 1 and 3 do not light up and the strobe signals from mpu seem not to be there.
The power supply LED's are all on. I measured all voltages (ok) and tested all fuses (ok). The MPU LED's are all on. The jumper settings are correct.
The game worked with all the old boards installed. It also worked with the original MPU and driver boards installed along with a new speech/sound and a new power supply board.
When I press switches on the playfield the driver board diagnostic LED's do react.
The machine was completely disassembled, cleaned and painted. The cabinet wiring looks good. All the wiring to the boards APPEARS to be correct.
Thanks in Advance for any input.
#2 21 days ago
How about showing the boards plugged in with the game on?
#3 21 days ago
will do
#4 21 days ago
#5 17 days ago
HAPPY NEW YEAR
#6 16 days ago
Happy New Year!
I wish I was familiar with these boards so I could help you. What was the reason for switching out the working/original boards?
#7 16 days ago
Can you press on these parts to see if it makes a difference? pasted_image (resized).png
If there is no difference, swap the (2) 6821 PIA 40 pin parts to see if that then allows the switches to work. If it does, then your lamp matrix may have an issue, but it would point at a failed part.
#8 16 days ago
Thought I'd chime in and suggest to check your tilt switches. Especially if you disassembled and repainted.
#9 16 days ago
Do those boards work in other games? If so check the dipswitches are 100% set for gorgar.
#10 16 days ago
Are the connectors below the backbox ok? I think there's 4 or 5 of them that go to the playfield & cabinet.
#11 16 days ago
So you have new MPU and Driver boards?
#12 16 days ago
Quoted from Skyemont:
Uh ... sentence 2 stated it and pictures of the boards proves it does.
Quoted from Boltronix:
$ 100.00
The Flipper Room
$ 14.00
$ 11.00
$ 12.00
Siegecraft Electronics
$ 50.00
$ 40.00
The Flipper Room
$ 799.00
$ 200.00
Professor Pinball
$ 39.00
Concealed Art
€ 60.00
Creo Pinball
$ 95.00
pinballmod
