As an update, here is what I saw when I went to my friends house to help him with the Gorgar:
The Q10 transistor (tip 102) and the pre driver have previously been replaced, as has the right slingshot coil. Presumably this problem has popped up previously and someone replaced all 3 items. That didn't work.
So, they presumably pulled the blue wire on connector 2J12 (pin 8 ) for that solenoid and sold the machine to my friend (a newbie with the itch since he has amassed 10 already over the last year).
I tested Q10 and the predriver as well as the coil's diode and they all tested within spec and similar to neighboring components.
I also pulled the 2N11 connector, which is the switch inputs, then re-connected the blue, pin 8 wire on 2J12, and the coil immediately locked on.
I believe that I have ruled out a bad switch, coil diode, switch diode, driver trans and pre-driver trans.
I suspect that the problem lies on the MPU/power driver board. So on vid's list above it would seem that it is a bad 7402 or bad PIA.
Any indication which component those two items are?
Thanks all!
