I have a problem with Gorgar. Displays are completely dead, no orange dot glow either. Gorgar is the first machine I bought (shopped does not mean everything was done correctly as far as fuses are concerned) and the last one I repinned the board edge connectors along with replacing the female connectors with new crimp connectors, new capacitors on PS. Did all the work at once. I have done this repining work to a handful of machines so maybe I was overconfident doing all at once.Powered it up and heard a crackling at transformer, displays went out. Found that the 1/4A sbl fuse was replaced with a much higher (15-20A) before I got it and I never checked this because it was working. That was over a year ago, I pulled the plug and walked away until yesterday out of frustration.
I found today that I switched the 2 black wires that go to the bridge rectifiers.
At this point if I remove all connections to the PS board except the 2 square power in ones(3J1&3J2) I have 95VAC at pin 4 on 3J1 and the bottom holder of F1, If I insert a 2A (a 1/4A sbl instantly blew the first try before changing the 2 black bridge rectifier wires around) fuse in F1 the voltage at pin 4 of 3J1 and F1 drop to 6.3V.
