Quoted from rottenrobert1313:Well I'm at a lost. Got the 12 volt supply line at a consistent 10.5 volts. New Cmos chip at IC19 and board still has both LED's locked on solid. While I did have the power supply board out I replaced the 4 capacitors on it. Also reflow solder on the header pins.
So.....who does board repair? And would you like my business?
Honestly it sounds like you may have two problems. A weak power supply and the MPU is locked up probably do to bad physical connections. I see the two LEDs lit up solid on the MPU. It has at least close to 5v to make the LEDs light up.
10.5v is flirting with the breakdown voltage of the LM323K. Add a current spike from flippers or solenoids and i could see the 5v dropping out.
Low unregulated voltage is a lot of times an indication of a failing filter capacitor. Set your meter for AC voltage, lowest voltage setting. Read across that test point and ground. If you see more than 0.25 VAC the filter cap can be considered failed.
I can repair and bulletproof your boards. I have rebuilt hundreds of these board sets, I am very proficient in repairing anything wrong with them. I will install all new header pins. New interconnect. New filter caps. New IC sockets. New 5w lamp column resistors. Clean the board front and back. 1 year warranty. I always recommend having the MPU and driver board serviced at the same time as they are interconnected.
MPU $50 ($60 with no battery NVRAM)
Driver $50
PSU $40
Sound and Speech $45
Andrew
