(Topic ID: 252144)
Gorgar heartbeat problem
By Mfox
  • 4 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by pincoder
#1 4 years ago
I am having an issue with my Gorgar. The heartbeat sound seems to progress to quickly and continues to beat even after a game ends. My sound board seems to be working correctly in test mode. I already reseated the chips on the sound board and replaced the 9-pin connector on the sound board as well as the 9-pin connector going to the CPU. Any thoughts would be appreciated.
Mike
#2 4 years ago
Faulty ribbon cable, cold soldier joints, bad scan be sockets.
#3 4 years ago
Quoted from Mfox:
Mike
Incorrect sounds/no reset:
Check in solenoid test that Sound pulses 9 to 13 produce a sound.
#4 4 years ago
See http://pincoder.ca for advance (and free) diagnostic ROMs. Specifically, start by reading the notes for the 11-sounds ROM. It will give you an understanding of how sounds are activated and, in the case of the heartbeat, cancelled. You might be able to then diagnose your problem before having to actually create a test ROM chip.
The Williams built-in solenoid test will allow you to check each of the 5 "solenoid/sound" signals, but it wont be able to send the "cancel" signal. No matter, you can still use the williams diagnostic to test for the "Tilt, Wire Twang, Dizzy, Extremely short burp, and Short Laser" sounds. Those sounds will stop playing automatically, but if you can't get it to play one or more of them you likely have a driver board issue.
Those sounds originate from PIA4 (Pins PB0-PB4) and come out of the driver board on 2J9 (Pins 9,7,1,2,3 respectively). If you can't play all of the above 5 sounds then this is where you need to start looking.
$ 170.00
Displays
Digipinball Shop
$ 40.00
The Flipper Room
$ 859.00
$ 11.00
$ 69.00
Pinball Pimp
2,900 (OBO)
Franklin, VA
$ 12.50
RoyGBev Pinball
Newcastle, OK
$ 1.29
Daddio's 3D Printed Mods
$ 69.00
Pinball Pimp
$ 42.95
Tools
Pincoder Store
$ 65.00
$ 27.95
This page was printed from https://pinside.com/pinball/forum/topic/gorgar-heartbeat-problem-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
