Hi group, thank you in advance for your help. I bought a Gorgar which I knew before I bought it that it did not work. I sent all three circuit boards to Tim at Nabours Novelty for repair. He replaced a lot of the capacitors, resistors, the male pins on the MPU and the female receptical on the driver board and a few other minor things. I get the boards back and the game started fine but had no sound or speech. I ended up sending him the sound & speech boards and he found several things wrong with them. I got them back and when I put them in, it has sound but no speech??? Some of the sounds are not correct but the typical Gorgar heartbeat works fine. I sent the boards back to him thinking he programmed something wrong. He installed them in a compatible game and all was good. He sent the sound & speech boards back to me along with a new game rom for my mpu. I installed the new game rom along with the sound & speech boards, turned game on, it still has that incorrect sounds and still no speech ? I took out the sound and speech boards and drove them to a friends arcade, Steve at RockFantasy (thanks Steve) and put them in his Gorgar and the sounds and speech work perfectly. I am stumped and so is Tim from Nabours Novelty. Does anyone have any suggestions?? PS, I checked all the connections on the boards and do not see anything I did wrong. I will post pictures. Thank you again in advance for any suggestions.
