(Topic ID: 221829)
Gorgar GAR Drop Targets not Resetting
By rickyray
1 year ago
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by Chalkey
#1 1 year ago
Need help troubleshooting my Gorgar "Gar" Drop Targets. I do not get a reset at the start of game, ball, or when all targets are down.
On Solenoid Test, no fire on 03.
On the switch test, "G" drops and 41 appears. Same with "A"= 42 and "R" = 43, but no immediate change to 44.
What is the likely culprit and where should I start. Already replaced the horseshoe contacts. Thanks.
#2 1 year ago
Quoted from rickyray:
Continuity of wires from horseshoe to board. See if you have a break.
#3 1 year ago
rickyray If the solenoid isn't firing in test you'd need to figure that out before working on the switches. If it's not something obvious like a loose wire I'd suspect the transistor on the driver board, or possibly a cold solder or connector issue. Do you know how to test the transistors with a multimeter?
#4 1 year ago
chalkey Just getting into the troubleshooting, so no I don't know how to test the transistors in particular. But willing to research or accept some instruction from someone like you. Thanks.
#5 1 year ago
I'm at pinburgh or I'd do something more detailed but try the "how to test a transistor" thread on this site. Basically set your dmm yo ohms and compare values between your 3 transistor legs to those on the working transistors on the board. There may be an unused but good transistor you can steal from the board.
#6 1 year ago
Take a wire lead, figure out which transistor fires that coil, touch the wire to the metal part of the transistor and the other end of the wire to ground. If the coil fires, your wiring is fine, if it doesn't start metering for continuity. That's where I would start. It will at least narrow down where to start looking.
#7 1 year ago
Thanks for all the input. I am learning a lot.
Update: We ran a wire lead from the Q19 transistor to ground and no fire. Just to verify we were doing it correctly, we ran the lead wire from Q21, the "GOR" transistor, and indeed the coil did fire.
Then we checked for wire continuity from the "GAR" coil to the driver board and we do have continuity.
But going back before the post, I had replaced the "GAR" coil because it looked fried (see attached photo). Now looking at the Q19 transistor area, there is also an area that looks burnt (see attached photo). I assume this is all a part of the issue.
Any thoughts on the next step or should I have an experienced service technician make the repair?
#8 1 year ago
Man, you really should have included that little nugget of info in your original post. I'd pass this one off to a tech unless you're good with board work and a soldering iron.
$ 22.00
$ 99.00
Pinball Sales
$ 12.00
Siegecraft Electronics
$ 9,000.00
$ 42.00
The MOD Couple
$ 229.99
$ 44.95
PinBoss Mods
Medisinyl Mods
$ 22.00
Metal-Mods
