At one point, there was a service bulletin addressing GI voltage above specification, in most cases around 8 volts. It involved installing a bridge rectifier in series with the GI fuse. The yellow GI wire was removed from the fuse holder, attached to the + and - terminals of the bridge. Then, a wire was run from the AC terminals of the bridge to the fuse holder. This dropped the GI voltage, and the bulbs ran cooler and lasted longer.
My Gorgar did not have that modification installed. Instead, a previous owner had installed a 6.3v filament transformer above the main transformer cage and was feeding the GI from that. I located the taped off original GI wiring, and hooked that back up. With LED load, I measured 7.9 volts. I then installed that 3rd bridge rectifier, as per the original bulletin, and ended up closer to 7 volts with load, still a bit high. I used a 20 amp bridge rectifier from NTE, which is supposed to have a 1.2v drop at 20amps. I suspect the LED load is low enough that I'm not getting as much forward voltage drop as I would with incandescent lamps.
Does anyone else have this GI modification? If not, what’s the voltage across the GI bulbs in your machine? I’m curious how prevalent this modification was.
